Problem with sending ADC output to LCD
pandu.ranganadh
View user's profile Send private message Visit poster's website AIM Address
PostPosted: Mon Apr 28, 2008 9:20 am     Reply with quote
Hi i am using PICDEM 2 Plus kit, this is below.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en010072&part=DM163022
I am using this kit for designing power supply. I am new to PIC and ccs compiler.
i have got pic16f877 lcd_flex driver. My kit has build in 10 ADC.
Please any one can send me ADC code and that ADC output should send to LCD which is already builtin.
Please send me as early as possiable.
Pand
PostPosted: Mon Apr 28, 2008 11:28 am     Reply with quote
This thread tells how to find which version of the PicDem2-Plus board
you have, so you can use the correct Flex lcd driver with it:
http://www.ccsinfo.com/forum/viewtopic.php?t=34385
This post has a program that shows how to read the trimpot on
the PicDem2-Plus board with the A/D converter on pin A0, and
display the result as a voltage on the LCD by using the Flex driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=32168&start=1
pandu.ranganadh
problem with using A1-A5 as Analog
PostPosted: Tue Apr 29, 2008 4:40 am     Reply with quote
Hi this code is working fine. Thank for sending replay,
But if we can connect Analog i/p to A0 then only its working, i need 7 or 8 or at least more than 5 analog i/p channels, how to take?
And also i want to display current rating also along with voltage, how it made ?
Pand
