one wire memory loop?
Scottl
PostPosted: Thu Mar 20, 2008 9:00 pm     Reply with quote
I have a DS1921G IButton kicking my A**! I have everything working fine but I cannot find a good method for retreiving all the logs.
The logs start at 1000h! I read the mission samples counter which is 24bits unsigned integer and I only read 16bits and then clear the IButton for the next mission.
I am using some code from the forum and I do not remember who posted it but thanks! See sample below:
unsigned int16 ds1921G_samples()
 int8 lsb, msb, csb;  // csb not needed for 16 bits
 unsigned int16 samples;
 float temp_log;
 onewire_reset();
 onewire_write(0xCC);
 onewire_write(0xF0);
 onewire_write(0x1B);
 onewire_write(0x02);
 lsb = onewire_read();
 onewire_reset();
 onewire_write(0x1A);
 msb = onewire_read();
 samples= make16(lsb, msb);      // 16 bits
 // Here I want to loop through the memory and get the data and send it to a pc.
for (i=0;i<=samples;++i)
 onewire_reset();
 onewire_write(?????????);  // Need to loop memory start to end LSB first 1000h
 onewire_write(?????????);  // MSB last starting at 1000h
 temp_log = onewire_read(); // byte
 temp_log = (float) temp_log / 2 - 40; // Maxim Conversion for DS1921G
 fprintf(COM_A, "I%3.1f\r", temp_log);
Does anyone have a good method on how I can loop through the LSB and MSB values to command the IButton for the data?
Thanks in advance,
Greg
jma_1
PostPosted: Mon Mar 24, 2008 6:02 pm     Reply with quote
Howdy,
I only briefly looked at the data sheet from Maxim. I think you can select the starting address for reading from memory. The flow chart on page 20 looks promising.
Mast Tx -> TA1(T7:T0), TA2 (T15:T8). Target address register indicate memory address to read.
Again, I only quickly scanned the datasheet and probably missed something crucial, but this looks a good path.
Cheers,
JMA
