Struct on the dSPIC...Help!
Kova
PostPosted: Sun Mar 02, 2008 9:51 am     Reply with quote
Hi all,
I have posted some days ago a post in the "PIC24/dsPICĀ® Compiler Comments" section but I haven't still resolved my problem :(
I have some problems with DSPIC30F4013 (also tried with 24FJ128GA010) and the structs :(
This is a piece of my code:
#include <30F4013.h>
#device adc=8
#FUSES FRC                      //Internal Fast RC Oscillator
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES WPSB16                   //Watch Dog Timer PreScalar B 1:16
#FUSES WPSA512                  //Watch Dog Timer PreScalar A 1:512
#FUSES NOPUT                    //No Power Up Timer
#FUSES BORV47
#FUSES LPOL_HIGH                //Low-Side Transistors Polarity is Active-High (PWM 0,2,4 and 6)
#FUSES HPOL_HIGH                //High-Side Transistors Polarity is Active-High (PWM 1,3,5 and 7)
#FUSES NOPWMPIN                 //PWM outputs drive active state upon Reset
#FUSES NOCOE                    //Device will reset into operational mode
//#FUSES ICS0                     //ICD communication channel 0
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#use delay(clock=8000000)
struct codeElement {
  long on;
  long off;
} const Table[] = {
  { 55,   0 },
  { 273,    92 },
  { 46,    92 },
  {  46,    46 },
  {  46,    46 },
  { 138,   135 },
  {  46,    46 },
  {  46,    46 },
  {  46,    46 },
  {  46,    46 },
  {  46,    46 }
.....//big Table
void main{
int i =0;
while (Table[i].on != 0) //Here crash!
cTest = (Table[i].on);
I have tested with Proteus and I receive "Illegal data memory access" error :(
I have tested with MPLAB SIM and it crashs and it gives me these errors :(:
CORE-E0004: Trap due to unimplemented FLASH memory access, occurred from instruction at 0x000100
CORE-E0004: Trap due to unimplemented FLASH memory access, occurred from instruction at 0x000102
CORE-E0004: Trap due to unimplemented FLASH memory access, occurred from instruction at 0x000104
CORE-E0004: Trap due to unimplemented FLASH memory access, occurred from instruction at 0x000106
CORE-E0004: Trap due to unimplemented FLASH memory access, occurred from instruction at 0x000108
Also, I have putted the struct in RAM with this code:
  int on;
  int off;
} Table[] = {
  { 55,   0 },
  { 273,    92 },
  { 46,    92 },
  {  46,    46 },
  {  46,    46 },
  { 138,   135 },
  {  46,    46 },
  {  46,    46 },
  {  46,    46 },
  {  46,    46 },
  {  46,    46 }
.....//big Table
But same problems :(
P.S.
I'm using CCS 4.068 version and the same code works perfectly on a PIC18F2550 Rolling Eyes
Sorry for my english
Bye
PostPosted: Sun Mar 02, 2008 1:11 pm     Reply with quote
Most of us have not bought the dsPIC compiler. It's very expensive and
it's very new. That's why questions about dsPIC don't get many answers.
