xindy Guest
warning: to prevent re-entrancy |
Posted: Tue Feb 26, 2008 10:22 pm |
hi everybody.. just a short question. why is it that when i use this code:
#INT_RDA
void SerialInt(void)
RXd_Data[Write_cntr] = fgetc(GSM);
Write_cntr=(Write_cntr+1) % BUFFER_size;
rda_flag=1;
it will create an error => interrupt disabled to prevent re-entrancy. it seems it has something to do with me using % but why? please help.. thanks guys. |
Posted: Tue Feb 26, 2008 11:40 pm |
It's not an error, it's a warning. Here is the message:
Quote: |
>>> Warning 216 "pcm_test.c" Line 85(0,1): Interrupts disabled during
call to prevent re-entrancy: (@DIV88) |
You can fix this warning by using the #org DEFAULT command.
This is from the CCS manual:
Quote: |
If the keyword DEFAULT is used then this address range is used for all
functions user and compiler generated from this point in the file until a
#ORG DEFAULT is encountered (no address range). If a compiler function
is called from the generated code while DEFAULT is in effect the compiler
generates a new version of the function within the specified address range.
Here's an example:
Code: | #include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,NOPUT, NOLVP
#define BUFFER_SIZE 50
int8 index;
int8 data[BUFFER_SIZE];
#org 0x100, 0x17F DEFAULT
#INT_RDA
data[index] = getc();
index = (index + 1) % BUFFER_SIZE;
#org DEFAULT
int8 a, b, c;
c = a % b;
Here's another example:
http://www.ccsinfo.com/forum/viewtopic.php?t=25464&start=4 |
Ttelmah Guest
Posted: Wed Feb 27, 2008 3:33 am |
As a 'comment' though, I'm a great advocate, of using binary buffer sizes to avoid this. If you make your buffer size, 8,16,32,64 bytes, then you can use:
Write_cntr=(Write_cntr+1) & (BUFFER_size-1);
Which (assuming buffer size is a constant), evaluates to just a couple of instructions. The compiler is smart enough to substitute just this operation, if the buffer is such a size, and '%' is used, which saves many instructions, and avoids the error message as well. :-)
RLScott
Posted: Wed Feb 27, 2008 1:00 pm |
PCM programmer wrote: |
..But be aware that indiscriminant use of #org DEFAULT can lead to code bloat, and the explosion of library use of your precious RAM locations. It is much better to avoid the need for this whole issue by trying to avoid the use of CCS library functions (including implicit functions like %) within an ISR. In the case at hand, you could do as Ttelmah suggested and use a power of 2 buffer size. That way you could perform your modulo addition on Write_cntr using the '&' operator, which does not invoke a CCS library function that needs to be protected from re-entrancy. Or, if you insist on a non-power-of-2 buffer size, you could to this:
Write_cntr++;
if(Write_cntr == BUFFER_size) Write_cntr = 0;
which also does not raise the spectre of re-entrancy.
Robert Scott
Real-Time Specialties |
kolio
Re: warning: to prevent re-entrancy |
Posted: Fri Feb 29, 2008 1:50 am |
xindy wrote: | hi everybody.. just a short question. why is it that when i use this code:
#INT_RDA
rda_flag=1;
Be careful with '%', which calls a hidden library DIV-routine as well as 'fgetc(GSM)'. Do not use these functions outside ISR when the interrupt is enabled. |
xindy Guest
Posted: Sun Mar 02, 2008 8:28 pm |
thanks guys.. i really appreciate all your help... |
