Hi.I need translate this code from hi-tech compiler to CCS.Is a timer interrupt????Thanks
void interrupt isr(void)
if (TMR1IF==1)
counter++;
if (counter==keepalive) //131 ms * counter keep_alive
//Go away I'm keep aliving
counter=0;
//CODE
TMR1IF=0;
_________________ To Pic Or No To Pic
Humberto
Posted: Wed Feb 27, 2008 9:39 am
Yes, it is an -open- TMR1 interrupt handler.
All you need is to define how to access TMR1IF. In most 16F series, it is the Bit0 of the
PIR1 Reg.
Credit to Mark who posted an alternative header with all the byte and bits definitions for
most 16F devices using union and structs. In this way it is possible to access a single
bit within a Register.
Don't put in any code for the TMR1IF flag. CCS handles it for you.
Saratoga
Posted: Thu Feb 28, 2008 1:29 am
Huooo .OK..
"if (TMR1IF==1)" is only for HI-tech.
It s 131ms timer x counter. I understand now.
Thanks to all.
The program is the ELM323 OBD chip firmware.
http://www.obdchip.com/node/20. I translate definitions code to CCS(gracias humberto XD). _________________ To Pic Or No To Pic
