pcd error--I/O error 103
sivaganapathy
PostPosted: Mon Feb 25, 2008 12:27 am     Reply with quote
hi,
I am using pcd demo compiler. I wrote in ccs and program it with mplab in explore 16 microchip development board. I am using 33fj256Mc710. When i try to compile i will get I/O error 103. How to solve it?
Is there another way to program explore 16 microchip development board using ccs ? I am using ICD2 as programmer.
#include <33FJ256MC710.h>
#use delay(clock=40000000)
#fuses hs,noprotect,NOWDT
#byte PORTA=5
set_tris_a(0);
 porta=0b00000000;
  do
  {   output_high(pin_a0);
      output_low(pin_a1);
      output_low(pin_a2);
      delay_ms(2000);
      output_low(pin_a0);
      output_high(pin_a1);
      output_low(pin_a2);
      delay_ms(2000);
      output_low(pin_a0);
      output_low(pin_a1);
      output_high(pin_a2);
      delay_ms(2000);
   } while(1);
PostPosted: Mon Feb 25, 2008 11:13 am     Reply with quote
CCS uses Delphi to make their IDE. Look at the following list of I/O
errors that come from Delphi. Also send an email to CCS support
and ask them to help you on this problem.
http://erikmartin.com/pro/ioerrors.html
