16f88 Pin 9 (CCP1) tied high locks up PIC
bownes
PostPosted: Fri Mar 14, 2008 4:35 pm     Reply with quote
I have a simple F88 circuit. Pin 9 has a 10k pullup on it. When I connect this pin, the PIC locks up. When I let it float, my code runs fine.
Using RS232 on RA2 and RA3.
I'm pretty sure the problem is in the initialization and set up code, but it isn't clear how to disable CCP1
Clues?
unsigned char c, cmd[15],command;
int i,x,y = 0;
setup_adc(ADC_OFF);
setup_ccp1(FALSE);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(False);
set_tris_b(0x00);
set_tris_a(0x0f);
while(1){
puts("CMD: ");
i=0;
c = getchar();
cmd[i] = c;
while ( c != CRLF ) { // read a command string
i++;
if(i == 20)
i=0;
c = getchar();
cmd[i] = c;
if (i>20) {
i=0;
puts("Error\n\r");
} else {
command=cmd[0];
switch (command)
case 's': // set a relay
x=(cmd[1]-'0');
printf("setting %d %c\n",x,cmd[1]);
set_relay(x);
puts("Set!\n\r");
case 'c': // clear a relay
clear_relay(cmd[1]-'0');
puts("Clear!\n\r");
case 'a': // clear all relays
clear_all_relays();
puts("Clear all\n\r");
case 'l': // set all relays
set_all_relays();
default: i=0;
PostPosted: Fri Mar 14, 2008 4:40 pm     Reply with quote
Yes, that's exactly what happens. Microchip decided to cost us one
million lost engineering hours (or student hours) by putting in a "low
voltage" programming mode that hardly anyone uses, and to enable
it by default.
Always post your #fuses. Much of the time, that's where the problem
will be. To fix your problem, add the NOLVP setting to your #fuses
statement. Do this in all your programs. In recent versions of the
compiler, CCS has started setting the fuse to NOLVP by default. So if
you forget to specify NOLVP, the compiler will do it for you. But you
have an earlier version, so you need to set it in the #fuses.
