OJ Guest
2 UARTS sharing a function call |
Posted: Wed Feb 20, 2008 2:28 pm |
I don't know how to explain this but I am trying to implement the use of two UARTs. I want to be able to share the same function call when extracting data from either buffer but I don't know how to go about it. Is there anyone that can help? Thanks in advance!
NOTE: this section inside get_packet() is not being printed correctly on this post.
Quote: | for(i=1; i<9> 0){OK++;}
this should be within the for loop: if(! strncmp ( temp,CMD[i],3)){command =i;}} followed by: if( command > 0) {OK++;}
The following code below works perfect for one UART:
#include <18F67J60.h>
#device adc=12
#FUSES NOWDT, WDT128, HS, NODEBUG, NOXINST, STVREN, NOPROTECT, FCMEN, IESO, ETHLED, PRIMARY, RESERVED
#use delay(clock=25000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=USB)
#use rs232(baud=9600,parity=N,xmit=PIN_B1,rcv=PIN_B0,bits=8,stream=UART)
#include <string.h>
#define BUFFER_SIZE 32
char packet[BUFFER_SIZE];
char USB_buffer[BUFFER_SIZE];
char UART_buffer[BUFFER_SIZE];
int index=0,next = 0;
int command,data_reg,length;
char CMD[9][4]="ERR","RTC","ADC","DAC","TCP","MMC","DIO","SLP","FLA"; //Command
int REG[9]={0,4,4,4,4,9,8,1,1}; // # of registers for each command
// Read example: CMD00\0x0D
// Write example: CMD10123456\0x0D
char temp[2];
/******************** Initialize Ports *****************************************/
void Initialize(void)
enable_interrupts(INT_RDA);
enable_interrupts(INT_EXT);
/******************** Serial Receive Interrupt *********************************/
#int_rda
void USB_Receive()
int t;
USB_buffer[index] = fgetc(USB);
t = index;
index = (index + 1) % BUFFER_SIZE;
if(index == next)
index = t;
#int_ext
void UART_Receive()
int t;
UART_buffer[index] = fgetc(UART);
t = index;
if(index == next)
index = t;
/******************** Get Character From Buffer ********************************/
#define DataAvailable (index!=next)
char get_char()
int t=0,timeout=false;
char c;
while(!DataAvailable)
t++;
delay_us(600);
if(t > 5){timeout = true; break;}
if(timeout){timeout = false; return (-1);}
c = USB_buffer[next];
next = (next + 1) % BUFFER_SIZE;
return(c);
/******************** Get Packet ***********************************************/
int get_packet()
int valid=true,i,OK=0;
command=0;
length=0;
packet[0] = get_char();
packet[1] = get_char(); //GET COMMAND
packet[2] = get_char();
for(i=0; i<=2; i++){temp[i] = packet[i];}
packet[3] = (get_char()- 48);
if((packet[3] == 0)||(packet[3] == 1)){OK++;} //GET R/W BIT
packet[4] = (get_char()- 48);
if((packet[4] >= 0 )&&(packet[4] <= REG[command])) //GET REGISTER BIT
data_reg = packet[4];
OK++;
if(packet[3]== 1)
for(i=5;i<BUFFER_SIZE; i++)
packet[i] = get_char(); //GET LENGTH OF DATA & DATA
length++;
if((packet[i] == 0x0D)||(packet[i] == -1)){length--; break;}
if(packet[length + 5] == 0x0D){OK++;} //GET CARRIAGE RETURN
packet[5]= get_char();
if(packet[5] == 0x0D){OK++;}
if(OK == 4){valid = true;}
else{valid = false;}
return valid;
/******************** Main Loop ************************************************/
Initialize();
while (true)
if(DataAvailable)
if(get_packet())
fprintf(USB,"command=%d bit=%d register=%d length=%d\n",command,packet[3],packet[4],length);
index = 0;next = 0;
I tried modifying the get_packet() & get_char() functions in the code below but it doesn't seem to work.
char get_char(char* buffer)
char c;
t++;
delay_us(600);
c = buffer[next];
return(c);
int get_packet(char* buffer)
command=0;
length=0;
packet[0] = get_char(buffer);
packet[1] = get_char(buffer); //GET COMMAND
packet[2] = get_char(buffer);
packet[3] = (get_char(buffer)- 48);
packet[4] = (get_char(buffer)- 48);
OK++;
if(packet[3]== 1)
packet[i] = get_char(buffer); //GET LENGTH OF DATA & DATA
length++;
packet[5]= get_char(buffer);
return valid;
Initialize();
while (true)
if(DataAvailable)
if(get_packet(USB_buffer))
index = 0;next = 0;
if(get_packet(UART_buffer))
fprintf(UART,"command=%d bit=%d register=%d length=%d\n",command,packet[3],packet[4],length);
index = 0;next = 0;
Ken Johnson
Joined: 23 Mar 2006 Posts: 197 Location: Lewisburg, WV
Posted: Wed Feb 20, 2008 3:10 pm |
1st - I don't know this part (sorry) - are these 2 hardware uarts? I'll assume yes; if not, I'm not sure you can pull this off.
2nd - assuming these are both active, you need separate indices for each buffer (you do have 2 separate buffers).
3rd - #int_ext is not a uart interrupt, do you want #int_rda2 ?
Well, that's my (maybe useless) comments, for starters. I didn't go into the meat of your code at all. Hope this helps a little.
Ken |
OJ Guest
Re: 2 UARTS sharing a function call |
Posted: Wed Feb 20, 2008 4:39 pm |
Thank you for your input but I managed to get it working....just need to clean it up a little.
Here is working code for extracting data from a packet (using two UARTs) using a shared function.
#device adc=8
#include <string.h>
int USB_i=0,USB_o=0,UART_i=0,UART_o=0,select=1;
char temp[2];
/******************** Initialize Ports ***************************/
ext_int_edge(H_TO_L);
/******************** Serial Receive Interrupt *******************/
#int_rda
void USB_Receive()
int t;
USB_buffer[USB_i] = fgetc(USB);
t = USB_i;
USB_i = (USB_i + 1) % BUFFER_SIZE;
if(USB_i == USB_o)
USB_i = t;
#int_ext
void UART_Receive()
int t;
UART_buffer[UART_i] = fgetc(UART);
t = UART_i;
UART_i = (UART_i + 1) % BUFFER_SIZE;
if(UART_i == UART_o)
UART_i = t;
/******************** Get Character From Buffer ****************/
#define USB_Data (USB_i != USB_o)
#define UART_Data (UART_i != UART_o)
char get_char()
char c;
if(select==1)
while(!USB_Data)
t++;
delay_us(600);
if(select==2)
while(!UART_Data)
t++;
delay_us(600);
if(select==1)
c = USB_buffer[USB_o];
USB_o = (USB_o + 1) % BUFFER_SIZE;
if(select==2)
c = UART_buffer[UART_o];
UART_o = (UART_o + 1) % BUFFER_SIZE;
return(c);
/******************** Get Packet *****************************/
int get_packet()
command=0;
length=0;
for(i=1; i<9;i++)
if (!strncmp(temp,CMD[i],3)){command = i;}
if(command > 0){OK++;}
if((packet[4] >= 0 )&&(packet[4] <= REG[command])) //GET REG BIT
OK++;
if(packet[3]== 1) //CHECK IF WRITE SELECTED
packet[i] = get_char(); //GET LENGTH & DATA
length++;
else //IF READ SELECTED END PACKET
return valid;
/******************** Main Loop ******************************/
Initialize();
while (true)
if(USB_Data)
select=1;
if(get_packet())
//Place Execute packet Routine here
USB_i = 0;USB_o = 0;
if(UART_Data)
select=2;
if(get_packet())
UART_i = 0;UART_o = 0;
