30f3010 header file question
PostPosted: Tue Feb 19, 2008 2:37 pm     Reply with quote
in 30f3010.h header file there is not any power pwm definition like 18f2431.h's pwm lines as;
// CCP Functions: SETUP_POWER_PWM()
// Constants used for SETUP_POWER_PWM() are:
#define PWM_CLOCK_DIV_4 0x00
#define PWM_CLOCK_DIV_16 0x04
#define PWM_CLOCK_DIV_64 0x08
#define PWM_CLOCK_DIV_128 0x0C
#define PWM_OFF 0x0000
#define PWM_FREE_RUN 0x8000
#define PWM_SINGLE_SHOT 0x8001
#define PWM_UP_DOWN 0x8002
#define PWM_UP_DOWN_INT 0x8003
#define PWM_OVERRIDE_SYNC 0x10000
#define PWM_UP_TRIGGER 0x00000
#define PWM_DOWN_TRIGGER 0x80000
#define PWM_DEAD_CLOCK_DIV_2 0x000000
#define PWM_DEAD_CLOCK_DIV_4 0x100000
#define PWM_DEAD_CLOCK_DIV_8 0x200000
#define PWM_DEAD_CLOCK_DIV_16 0x300000
// Constants used for SET_POWER_PWMx_DUTY() are:
#define PWM_UPDATE_DISABLE 0x20000
#define PWM_UPDATE_ENABLE 0x00000
// Constants used for SETUP_POWER_PWM_PINS() are:
//#define PWM_OFF 0
#define PWM_ODD_ON 1
#define PWM_BOTH_ON 2
#define PWM_COMPLEMENTARY 3
so can i use power pwm functions of 30f3010 chip, without add any definitions to its header file...
Thanks for pay attention...
