WDT confusion
guest110
WDT confusion
PostPosted: Tue Feb 19, 2008 2:59 pm     Reply with quote
I am using a PIC18F4685. There is a possibilty of an endless loop (based in some external hardware) I want to activate the WDT only at this time. Can I use set_up_wdt(wdt_on) and set_up_wdt(WDT_OFF) to selectively activate and deactivate the watch dog? If this is true what is the proper fuse setting NOWDT or WDT ?
Thanks for any help
Bob Sacamano
PostPosted: Tue Feb 19, 2008 3:25 pm     Reply with quote
From the datasheet:
PIC18F2682/2685/4682/
4685 devices have a Watchdog Timer, which is either
permanently enabled via the Configuration bits or
software controlled (if configured as disabled).
and also
SWDTEN: Software Controlled Watchdog Timer Enable bit(1)
1 = Watchdog Timer is on
0 = Watchdog Timer is off
Note 1: This bit has no effect if the Configuration bit, WDTEN, is enabled.
and finally
bit 0 WDTEN: Watchdog Timer Enable bit
1 = WDT enabled
0 = WDT disabled (control is placed on the SWDTEN bit)
So if you use the NOWDT fuse, then the WDT is software controlled.
If you use the WDT fuse, then the WDT is permanently enabled.
This was an especially confusing point for me to remember when I first started using these PICs. The naming convention of the configuration bit/fuse setting is a bit peculiar at best.
"And you want to be my latex salesman."
guest100
PostPosted: Tue Feb 19, 2008 3:55 pm     Reply with quote
thanks seinfeld fan
