joven
Joined: 30 Jan 2007 Posts: 56 Location: Viana do Castelo - Portugal
HTTP server + MMC + FAT |
Posted: Sun Feb 17, 2008 12:27 pm |
Hi
I'm trying put ethernet and MMC with fat32 work together.
I'm using the example 15 from tcp/ip stack for show the text inside of txt file.
When compile give-me many errors on the driver "mmcsd.c".
The error is "*** Error 12 "D:\projpic\dhcpmonitor\mmcsd.c" Line 354(25,34): Undefined identifier mmcsd_spi"
// ex15.c - Example 15 from the Embedded Internet/Embedded Ethernet tutorial
// A webserver that accepts GET and POST commands.
// NOTE: Change the code in IPAddrInit() to your desired IP address, which
// is based on your network.
#define STACK_USE_ICMP 1
#define STACK_USE_ARP 1
#define STACK_USE_TCP 1
#define STACK_USE_HTTP 1
#define STACK_USE_DHCP 1
#include "ccstcpip.h"
#include <stdlib.h> // for atoi32
#include "cmd_mmc.c"
char HTML_inicial_PAGE[100]="tudo bem?";
//here is this examples / page
const char HTML_INDEX_PAGE[]="
<HTML><BODY BGCOLOR=#FFFFFF TEXT=#000000>
<IMG SRC=\"http://www.ccsinfo.com/pix/CCSlogotiny.gif\"><P>
<H1>CCS HTTP/CGI EXAMPLE</H1>
<FORM METHOD=GET>
<P>LCD: <INPUT TYPE=\"text\" NAME=\"lcd\" size=20 maxlength=16>
<BR>LED1:<INPUT type=\"radio\" name=\"led1\" value=1>ON
<INPUT type=\"radio\" name=\"led1\" value=0 checked>OFF
<BR>LED2:<INPUT type=\"radio\" name=\"led2\" value=1>ON
<INPUT type=\"radio\" name=\"led2\" value=0 checked>OFF
<BR><INPUT TYPE=\"submit\"></FORM>
<P><A HREF=\"/analog\">Analog Readings</A>
</BODY></HTML>
const char HTML_ANALOG_PAGE[]="
<H1>PICNET ADC READINGS</H1>
<P>%0
<BR>%1
<P><A HREF=\"/\">Change LCD/LEDs</A>
</BODY></HTML>
//this is a callback function to the HTTP stack. see http.c
//this demo provides to web "pages", an index (/) and an about page (/about)
int32 http_get_page(char *file_str) {
int32 file_loc=0;
static char index[]="/";
static char about[]="/analog";
printf("\r\nRequest %s ",file_str);
if (stricmp(file_str,index)==0)
file_loc=label_address(HTML_INDEX_PAGE);
else if (stricmp(file_str,about)==0)
file_loc=label_address(HTML_ANALOG_PAGE);
if (file_loc)
printf("(FILE=%LU)",file_loc);
printf("(File Not Found)");
return(file_loc);
// this demo provides handling for two formatting chars, %0 and %1.
// %0 is ADC for channel 0, %1 is ADC for channel 1.
int8 http_format_char(int32 file, char id, char *str, int8 max_ret) {
char new_str[20];
int8 len=0;
int8 i;
*str=0;
switch(id) {
case '0':
set_adc_channel(0);
delay_us(100);
i=read_adc();
strcpy(new_str,HTML_inicial_PAGE);
//sprintf(new_str,"<B>AN1 = </B>0x%X",i);
len=strlen(new_str);
case '1':
#if STACK_USE_CCS_PICNET
set_adc_channel(1);
delay_us(100);
i=read_adc();
#else
len=0;
if (len) {
if (len>max_ret) {len=max_ret;}
memcpy(str,new_str,len);
return(len);
//in this example it verifies that "pwd" is "master", if it is
//then it sets led1 and led2 ("led1" and "led2") based on their value
//and changes the lcd screen ("lcd").
void http_exec_cgi(int32 file, char *key, char *val) {
static char led1_key[]="led1";
static char led2_key[]="led2";
static char lcd_key[]="lcd";
int8 v;
printf("\r\nCGI FILE=%LD KEY=%S VAL=%S", file, key, val);
if (stricmp(key,led1_key)==0) {
v=atoi(val);
if (v) {output_low(USER_LED1);}
else {output_high(USER_LED1);}
if (stricmp(key,led2_key)==0) {
v=atoi(val);
if (v) {output_low(USER_LED2);}
else {output_high(USER_LED2);}
void main(void) {
int8 i;
char nome[20];
FILE stream;
set_tris_a(0b11111100);
set_tris_f(0b11111001);
MACAddrInit();
set_tris_c(0b11010011);
output_low(PIN_F1);
output_low(PIN_F2);
i = fat_init();
if (i)
output_high(PIN_F1);
output_high(PIN_F2);
//display
output_low(PIN_F1);
output_low(PIN_F2);
if(fatreopen("/ficheiro.txt", "r", &stream) != GOODEC)
fatreopen(nome, "r", &stream);
fatgets(HTML_inicial_PAGE, 99, &stream);
fatclose(&stream);
StackInit();
while(TRUE) {
StackTask();
I have put work the http and mmc separated.
Thanks |
Posted: Sun Feb 17, 2008 12:44 pm |
Quote: | Undefined identifier mmcsd_spi |
"mmcsd_spi" is defined as the stream in the #use spi() statement.
Look on line 126 of the mmcsd.c file, as shown in bold below:
Quote: |
#use spi(MASTER, DI=MMCSD_PIN_SDI, DO=MMCSD_PIN_SDO,
CLK=MMCSD_PIN_SCL, BITS=8, MSB_FIRST, IDLE=1, stream=mmcsd_spi)
joven
Posted: Mon Feb 18, 2008 5:34 am |
why give-me error? I only have the mmc connected to hardware spi.
I'm using a 18F67J60, have the ethernet encoder inside.
If i remove the "stream=mmcsd_spi" compile, but do not work.
The idea i have of the stream is when i have more devices easily can identify and send our receive data.
thanks |
