How do I count pulse width ?
ac34856
PostPosted: Mon Dec 14, 2009 10:39 am     Reply with quote
I am reading an encoder for velocity and I would like to calculate the speed using the encoder pulse width.
I have tried doing this using an External Interrupt INT_EXT to start timer 1
but couldn't work out how to stop the timer on the falling edge so that the count relating to pulse width (and hence velocity) could be read.
Of course if the shaft isn't moving it will also need to cater for this and time out within 1 second for example.
Any help would be appreciated -
Rob
PostPosted: Mon Dec 14, 2009 11:18 am     Reply with quote
The CCP (in capture mode) is designed to do this.
CCS has an example file which uses both CCP modules to do it:
c:\program files\picc\examples\ex_ccpmp.c
This thread has sample code to do it with one CCP module:
http://www.ccsinfo.com/forum/viewtopic.php?t=31470
ac34856
Thanks ... but ...
PostPosted: Tue Dec 15, 2009 6:04 am     Reply with quote
Yes that routine was tested yesterday and works mostly ok above
500Hz.
If I wanted to count very slow pulses say down to 10Hz it
would need to wrap around which obviously means more bits
counting resolution.
In its present form it works ok down to above 100Hz after which
the counter gets into trouble.
Ideally I would need to increase the counter resolution to 32 bits
is there a quick way to do this ?
Rob
