nuwavedc
PIC16F884 port initialization problem |
Posted: Wed Feb 06, 2008 2:20 pm |
****MYSTERY SOLVED****
Stupid hardware mistake. Used QFN pinout on a TQFP layout.
CCS PCM C Compiler, Version 4.025, PIC 16F884
For some reason no matter what I do I cannot get port C0 and port RA6 to output.
This has me stumped, and I am 99.9% sure this is not hardware related after 3 prototypes are exhibiting the same problem.
I am using fast IO statement on all of the ports to save some code space and controlling the tris registers manually (although letting the compiler set port direction by not using fast IO and tris statements does not help)
The remainder of my code is working perfectly. I am running a 3 digit LCD display, getting A/D samples, getting keypresses, sending a PWM to a beeper, sending a pwm to a backlight, etc. This is bizarre, its only Pins C0 and A6 that seem not to be setup correctly.
Code: | #inline
void HardwareInit(void)
setup_adc_ports(sAN0|sAN2|VSS_VREF);
setup_adc(ADC_CLOCK_DIV_32);
setup_spi(FALSE);
setup_wdt(WDT_18MS);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); //Rollover 32.768mS
setup_timer_2(T2_DIV_BY_4,255,1); //Rollover 0.51mS
setup_oscillator(OSC_8MHZ); //4 Mhz with div 4 prescaler
setup_ccp1(CCP_PWM);
setup_ccp2(CCP_PWM);
set_pwm1_duty(0);
set_pwm2_duty(0);
set_tris_e(0x00); //all port e pins are outputs
set_tris_d(0x00); //all port d pins are outputs
set_tris_c(0x00); //all port c pins are outputs
set_tris_b(0x07); //RB0,1,2 all inputs 1 = inputs, 0 = outputs
set_tris_a(0x0D); //RA0,2,3 are inputs
Port_b_pullups(0x07);
(from our setup.h)
#include <16F884.h>
#device adc=10
#FUSES WDT //Watch Dog Timer
#FUSES PUT //Power Up Timer
#FUSES PROTECT //Code protected from reads
#FUSES CPD //Data EEPROM Code Protected
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES WRT //Program memory write protected
#FUSES BORV40 //Brownout reset at 2.1V
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
//Interrupt priorities:
#priority timer2,timer1
_________________ Thanks,
NuWaveDC
Posted: Wed Feb 06, 2008 4:54 pm |
Make a simple test program that does nothing except toggle those pins.
Get rid of at least 90% of your code. Turn off the watchdog. Don't do
any code protection. Don't use fast i/o. Let the compiler handle the TRIS.
Don't enable interrupts (you have no interrupt service routine). Don't
enable or disable all those peripheral modules.
Here's an example of a test program:
http://www.ccsinfo.com/forum/viewtopic.php?t=32982&start=1 |
nuwavedc
Probably Should Clarify... |
Posted: Thu Feb 07, 2008 9:38 am |
I will try a simplification as you suggested, but I probably should mention that the remainder of my code is working perfectly. I am running a 3 digit LCD display, getting A/D samples, getting keypresses, sending a PWM to a beeper, sending a pwm to a backlight, etc. This is bizarre, its only Pins C0 and A6 that seem not to be setup correctly. FYI there is an ISR in my ISR.C. Mainly wondering if anyone has run into similar circumstances _________________ Thanks,
NuWaveDC |
nuwavedc
Solved |
Posted: Thu Feb 07, 2008 1:47 pm |
Stupid hardware mistake. Used QFN pinout on a TQFP layout. _________________ Thanks,
NuWaveDC |
