Having trouble with PORTB1 and B2
cypher
PostPosted: Fri Jan 25, 2008 1:26 pm     Reply with quote
I'm trying to read PORT B. However, pins B1 and B2 are always high for some reason. I have set_tris_b(0xFF) but it doesn't make a difference. Looking at the datasheet it says port b has a weak pull-up and they can be swicthed on by clearing the RBPU bit in the INTCON2 register. I don't know if it will make a difference. But how do you set internal registers in this complier. I don't think the compiler allows setting internal register bit on/off like other compilers.
Any suggestions on how to read B1 and B2?
PostPosted: Fri Jan 25, 2008 1:35 pm     Reply with quote
Post your PIC, compiler version, a compilable test program, and a list
of external hardware connections (if applicable).
Do this in all questions.
cypher
Code
PostPosted: Tue Jan 29, 2008 4:22 pm     Reply with quote
Here's the code I have:
#include <18F6722.h>
#device ADC=10
#include <stdio.h>
#include <math.h>
#include <ctype.h>
#include <stdlib.h>
#fuses INTRC_IO,NOWDT,NOLVP
#use delay(clock=8000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8, force_sw, invert)
#use standard_io(A)
#use standard_io(B)
#use standard_io(C)
#use standard_io(D)
#use standard_io(E)
#use standard_io(F)
#use standard_io(G)
#define     SW_EN      PIN_B0
#define   SW_MODE      PIN_B1
#define   SW_TEMP0                   PIN_B2
#define   SW_TEMP1                   PIN_B3
#define   SW_TEMP2                   PIN_B4
#define   SW_TEMP3                   PIN_B5
#define   SW_TEMP4                   PIN_B6
#define   SW_TEMP5                   PIN_B7
void main (void)
set_tris_b(0xFF);
int r_sw_en      =   0;
int r_sw_mode      =   0;
int r_sw_temp0      =   0;
int r_sw_temp1      =   0;
int r_sw_temp2      =   0;
int r_sw_temp3      =   0;
int r_sw_temp4      =   0;
int r_sw_temp5      =   0;
r_sw_en      =   input(SW_EN);
r_sw_mode   =   input(SW_MODE);
r_sw_temp0   =   input(SW_TEMP0);
r_sw_temp1   =   input(SW_TEMP1);
r_sw_temp2   =   input(SW_TEMP2);
r_sw_temp3   =   input(SW_TEMP3);
r_sw_temp4   =   input(SW_TEMP4);
r_sw_temp5   =   input(SW_TEMP5);
printf("%d\r",r_sw_en);
printf("%d\r",r_sw_mode);
printf("%d\r",r_sw_temp0);
printf("%d\r",r_sw_temp1);
printf("%d\r",r_sw_temp2);
printf("%d\r",r_sw_temp3);
printf("%d\r",r_sw_temp4);
printf("%d\r",r_sw_temp5);
PostPosted: Tue Jan 29, 2008 4:32 pm     Reply with quote
and a list of external hardware connections (if applicable).
cypher
Code
PostPosted: Tue Jan 29, 2008 4:59 pm     Reply with quote
1. I'm using a PIC18LF6722
2. Compiler version - 4.047
3. Code posted as above
4. I just have a 470 Ohm in series to each portb pin and 10K pull-ups for the DIP switch which i'm using as the input on/off.
Wayne_
PostPosted: Wed Jan 30, 2008 3:45 am     Reply with quote
you don't need to have the #use standard_io if you are using standard_io and you definately don't want that set_tris_b in there.
The PORT_B PULLUPS are off on power up unless you specify them to be on and if that were the problem you would see it on the other pins as well.
I am using the same chip but with a different compiler and I am having no problems.
Can you check your hardware ? have you got a multimeter or something to physically check B0 and B1 ?
cypher
PostPosted: Mon Feb 04, 2008 4:30 pm     Reply with quote
Ok, so I removed the standard_io and the tris statements and still no luck. Also I checked the voltage on the inputs, and it seems ok.
PostPosted: Mon Feb 04, 2008 5:25 pm     Reply with quote
Are these tests being done with a hardware board or with a simulator ?
ELCouz
PostPosted: Mon Feb 04, 2008 10:31 pm     Reply with quote
Try another pic , sometimes pic pins i/o might die when doing test...
