asmallri
fprintf misunderstanding? |
Posted: Sun Feb 03, 2008 2:12 pm |
I am not sure if this is a bug or my misunderstanding. I am using 4.053
I have the following declarations
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8, STREAM=CONSOLE)
#use rs232(baud=2400,parity=N,xmit=PIN_G1,rcv=PIN_G2,bits=8, STREAM=DATA)
If I do this..
fprintf(DATA,"This is on the DATA port\r\n");
printf("This should be on the CONSOLE port\r\n)"
Both lines print on the DATA port. But if I do the following
fprintf(CONSOLE,"This is on the Console port\r\n");
Then the data message appears on the data port and the CONSOLE messages both appear on the console port. It appears the printf uses the output routines from the last STREAM.
Is this what is supposed to happen? _________________ Regards, Andrew
Posted: Sun Feb 03, 2008 2:50 pm |
Yes, I think so. If you use streams, everything should be a stream.
This includes the declarations and the print statements. |
Posted: Sun Feb 03, 2008 3:22 pm |
Historically, STDIO (which is what is used without a stream declaration), is always the _last_ #USE RS232 declaration the compiler has met. This is still true.
asmallri
Posted: Sun Feb 03, 2008 3:27 pm |
In this case it is now broken. The stdio changes to whatever last fprintf stream was used. _________________ Regards, Andrew
