Joined: 14 Feb 2007 Posts: 46 Location: Greece & Cyprus
How to send long value over USART??
Posted: Thu Jan 31, 2008 1:57 pm
HI
I'm working a project need to send long value numbers serialy.
Does any one now how can i sent long value over Usart ??
Let's say i whant to sent a number 1234.12 how can i do this?
putc() , fputc() send only character ,So how do i sent Long Value?? _________________ ---- GREECE ----
E_KARVELAs
Posted: Thu Jan 31, 2008 2:07 pm
Need to send From PIC micro to PIC micro.
Not PIC TO PC.
thanks _________________ ---- GREECE ----
SherpaDoug
Posted: Thu Jan 31, 2008 3:35 pm
If you just want to send a 16 bit long you can use make8() and make16() to break the long into bytes. A number like 1234.12 is a float which requires make32() to reconstruct.
Or you can use printf() and maybe gets() to send the number as a string. _________________ The search for better is endless. Instead simply find very good and get the job done.
E_KARVELAs
Posted: Fri Feb 01, 2008 7:44 pm
HI
I found this in the compiler :
main() {
char string[20];
float f;
f=12.345;
sprintf(string," \f % 6.3 f ", f );
//in this case string[20] contein the float but coverted into char
Question!!!
getc() or fgetc()return a character.
What does the fgets() return from usart ???
didn't figure it out .
