PICoHolic
PIC18F2550 USB using internal OSC |
Posted: Tue Jan 29, 2008 4:47 am |
What proper configuration bits settings in order to get the 18F2550 USB run using the internal 8MHz oscillator?
I'm using the following configuration:
#FUSES INTHS // OSC!?!?!?!?!?!?
#FUSES PROTECT //Code protected from reads
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES PLL2 //Divide By 2(8MHz oscillator input)
#FUSES CPUDIV1 //No System Clock Postscaler
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
...and...
setup_oscillator(OSC_8MHZ|OSC_TIMER1|OSC_31250|OSC_PLL_OFF);
Posted: Tue Jan 29, 2008 7:55 am |
Forget it.
The internal oscillator, is several orders of magnitude too inacurate to be used for USB. This is why, if you look at the oscillator diagram, there is no route from the internal oscillator, to the USB circuitry. Hence no fuse pattern to make this work, and even if there was, it wouldn't be reliable.
The internal oscillator, is _only_ for use for the CPU. It can't run the USB.
PICoHolic
Posted: Tue Jan 29, 2008 8:39 am |
Yes,
I have noticed that there is no route from the internal oscillator, to the USB circuitry. I'll use an external OSC
Thank you Ttelmah |
