Ramey
| preprocessor token pasting |
Posted: Tue Jan 29, 2008 12:35 am |
I've written
#define CODE(n, c, m, d, u) INDEX_CODE_ ## n,
which intended to expand the following
CODE(NULL, 0, 0, 0, 0)
to:
INDEX_CODE_NULL
but fails to do so. It seems that the ANSI C pre-processor operator ## doesn't work. Does anyone know anything about this. Is there some sort of way to get the same effect?
Robert Ramey |
Posted: Tue Jan 29, 2008 3:38 am |
There must not be a space between the '##', and the 'n', to get the 'one piece' result required in CCS.
Also, you may have a problem, if you have stddef.h loaded (which is automatically loaded by several of the other include files), since CCS, does not have/support a 'NULL' data type, and therefore has it defined in this file as '0'. So your line expands as:
INDEX_CODE_0
If this is already included...
