Mark Weir
SIOW Multiple Sessions |
Posted: Wed Jan 23, 2008 6:28 pm |
Hi All
Does anyone know if it is possible to run several sessions of the siow serial port monitor at the same time? Each one connected to a different prot of course.
If not can anyone suggest an easy to use serial port monitor that can.
Cheers
Mark _________________ Life is too short to avoid asking questions |
Douglas Kennedy
Posted: Wed Jan 23, 2008 7:19 pm |
More than one copy of SIOW will launch on a windows machine as they will run in different threads but the driver will be blocking. This means that you will need need more than one hardware uart on your PC ...there is not necessarily a one to one relationship between port names Comx and the hardware to which they are linked but if you try them one by one and you have the PC uart hardware you will be able to get a second or more copies of SIOW running. |
rnielsen
Posted: Thu Jan 24, 2008 9:36 am |
Simply have each one set up to use a different COM port. If you only have COM1 & COM2 then you can only have two windows up at once. As soon as you try to have both windows using the same port then your operating software will let you know that it's a 'no-no'.
Ronald |
treitmey
Posted: Thu Jan 24, 2008 9:40 am |
YES.
I have a 8 port USB-serial and use multiple siow all the time.
1 for debug
1 for input
1 for second debug
1 for second input...
I put a copy in different folders then they stay setup differently for each port
com5-19200,n,8,1
com6-1200,e,8,1
com7-9600,n,8,1 ...
one note on USB to serial adapters. try to find one that doesn't use the FTDI chip. The ICD-U40 uses the FTDI chip and there can be issues. My USB to serial uses the Prolific chip. works great! |
Mark Weir
multiple SIOW |
Posted: Sun Jan 27, 2008 2:34 pm |
Thanks you all for your great responses.
I have succeded using treitmey's method.
Cheers
