YM Guest
Using the I2C protocol between two PIC18F4431s |
Posted: Fri Jan 25, 2008 9:29 am |
I am fairly amateur at microcontroller programming and definitely lacking in I2C knowledge so I will ask a couple of simple (read: ignorant) questions:
1) Is it possible to use a PIC18F4431 as a slave in the I2C protocol?
2) Are there certain pins which MUST be used for I2C communications?
Now, here is the code I'm using:
Master)
The following code sends the correct signal from the master (I have truncated everything but code immediately relevant).
Code: | setup_oscillator(OSC_8MHZ);
#use i2c(master, sda=PIN_C4, scl=PIN_C5)
setup_power_pwm_pins(PWM_BOTH_ON ,PWM_OFF, PWM_OFF, PWM_OFF);
setup_power_pwm(PWM_CLOCK_DIV_64|PWM_FREE_RUN,1,0,4095,0,1,0);
data_out =122;
address = 0x20
i2c_start();
i2c_write(address);
i2c_write(data_out);
i2c_stop();
Slave)
The code compiles and runs all the way through without a problem, however it seems that when it receives the signal from the master it assigns a random value to the data_in variable. What is stranger still is that the random value is not so random: it is always odd and seems to be a few numbers more often than others (255, 121, 253, etc).
#use i2c(SLAVE, SDA=PIN_D2, SCL=PIN_D3, address=0x20)
setup_power_pwm_pins(PWM_BOTH_ON ,PWM_BOTH_ON, PWM_BOTH_ON, PWM_BOTH_ON);
i2c_start();
data_in = i2c_read();
i2c_stop();
I then check the data_in value through a LED display.
To recap: What am I doing wrong? Or what am I not doing, that I should be to make my slave understand my master’s signal?
Thank you for your help! |
Posted: Fri Jan 25, 2008 11:18 am |
Look in the examples, at EX_SLAVE.C
The slave device, does not, and cannot generate either I2C start, or stop. These are both done by the _master_ device. The slave needs to simply sit, and wait, either for the I2C interrupt (or polling I2C_DATA_IS_IN).
Yes, to implement a _slave_ device, the hardware I2C pins, really must be used (it would probably be possible to write a slave using other lines, but you would be talking hundreds of lines, of very carefully written and complex code.....). These pins are D3, for the clock, and D2, for the data, which you are using.
Also, you don't mention having the pullup resistors on the lines. These are _essential_.
rnielsen
Posted: Fri Jan 25, 2008 1:28 pm |
There are boat loads of working code posted in this forum. Look in the 'working code' section and take a look at what other people have used. That will give you an idea of both master and slave code.
Remember, start simple with just the basics necessary. Then, when you're sure you have things talking properly, add more code to get to where you want things to be.
An oscilloscope is extremely handy when trying to see what is going on between each device. You can see if the slave is ACKing back and if it's handling each instruction, from the master, in time.
Ronald |
