Problems with power up .. losing spi initialization
Eugeneo
PostPosted: Tue Apr 19, 2005 10:27 pm     Reply with quote
I've written a program using a pic16f819. For some reason everything everything works except on ocasion, the spi port is not initialized. When this happens the program functions normally but with no spi interface.
Here is a segment of my program. As you can see I've setup the spi port 3 times and the problem seems to get better by 70%. Has anybody seen this probem before.
OSCCON=OSC_8MHZ;
setup_spi(SPI_SLAVE | SPI_H_TO_L | SPI_CLK_DIV_16);
enable_interrupts(INT_SSP);
setup_wdt(WDT_144MS);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8); setup_ccp1(CCP_COMPARE_INT); // Configure CCP1 to set
enable_interrupts(INT_CCP1);
set_timer1(0);
CCP_1=500;
enable_interrupts(GLOBAL); do
PostPosted: Wed Apr 20, 2005 12:59 am     Reply with quote
Sounds like a wacky problem. What's your version of the compiler ?
gator
PostPosted: Thu Jan 24, 2008 9:39 pm     Reply with quote
Has anybody else seen this problem? I am experiencing the same issue.
Sometimes the spi will not work on reset but everything else appears to function properly. Once the spi gets up and running though it works without any problems.
The code I am using is:
#byte SSPSTAT = 0x94
#byte SSPCON = 0x14
#byte TRISA = 0x85
#byte TRISC = 0x87
#byte SSPBUF = 0x13
#byte PIR1 = 0x0c
#byte PIE1 = 0x8c
#byte PORTB = 0x06 // 106
#byte PCON = 0x8E
#byte STATUS = 0x03
#byte TRISB = 0x86
#define SSPIF 0x08
char DVD_BufferIn[BUFFER_SIZE];
char DVD_BufferOut[BUFFER_SIZE];
char Vault_Buffer[BUFFER_SIZE];
int DVD_counterIn;
int DVD_counterOut;
int Vault_counter;
int test_led_glow;
short int SPI_READ_DATA;
short int SPI_SEND_DATA;
byte SSPBUF_OUT;
byte DVD_response_is_ready;
byte DVD_message_started;
byte Vault_message_started;
byte tempcount;
byte reset_POR;
byte reset_BOR;
byte reset_TO;
byte reset_PD;
#define NUL 0x0
#define STX 0x2
#define ETX 0x3
#define ENQ 0x5
#define STATUS_LED PIN_B0 // output
#define POR_RESET PIN_B1 // POR RESET
#define BOR_RESET PIN_B2 // BOR RESET
#define TO_RESET PIN_B4 // TO
#define PD_RESET PIN_B5 // PD
// init_hardware - Hardware initialization
// Initializes the hardware to its correct state.
init_hardware()
SSPCON &= 0xDF;
SSPCON = 0x04;
SSPCON |= 0x20;
SSPBUF &= 0x00; // clear SSPBUF
SSPSTAT = 0x00;
TRISC = TRISC & 0xDF;
TRISC = TRISC | 0x08 ;
ADCON1 |= 0x0F;
TRISA &= 0x00;
TRISA |= 0x20;
TXSTA = TXSTA & 0xEF; // set synchronous SCI mode
TXSTA = TXSTA | 0x04;
RCSTA = RCSTA | 0x10;
SPBRG = SPBRG | 0x0B;
// main - main control loop
main()
TRISB &= 0xC8; // SET TRISB to O/P 0xuu00u000
DVD_counterIn = 0;
DVD_counterOut = 0;
Vault_counter = 0;
tempcount = 0;
test_led_glow = 0;
#use delay(clock=3680000)
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7)
// wait till power stable
// clear buffers
for (byte i = 0; i < BUFFER_SIZE; i++)
DVD_BufferIn[i] = 0x0;
DVD_BufferOut[i] = 0x0;
Vault_Buffer[i] = 0x0;
init_hardware();
enable_interrupts(INT_RDA);
reset_BOR = PCON & 0x01;
reset_POR = PCON & 0x02;
reset_TO = STATUS & 0x10;
reset_PD = STATUS & 0x08;
PCON |= 0x03;
#INT_SSP
void spi_isr()
byte tempdata;
byte i;
if ( SSPSTAT & 0x01 )
tempdata = SSPBUF;
if ( DVD_response_is_ready == TRUE )
SSPBUF = DVD_BufferIn[DVD_counterIn];
if ( DVD_BufferIn[DVD_counterIn] == ETX )
DVD_response_is_ready = FALSE;
DVD_counterIn= 0;
DVD_counterIn++;
SSPBUF = 0xAA;
// process the new incoming data
if ( tempdata != ENQ )
switch ( tempdata )
case STX: Vault_Buffer[0] = STX;
Vault_counter = 1;
Vault_message_started = TRUE;
case ETX: if ( Vault_message_started == TRUE )
Vault_Buffer[Vault_counter] = ETX;
for (i = 0; i <Vault_counter> 1 && Vault_counter > Vault_Buffer[1]) || Vault_counter >= (BUFFER_SIZE - 1) )
Vault_counter = 0;
Vault_message_started = FALSE;
for (i = 0; i <BUFFER_SIZE>= BUFFER_SIZE - 1 )
DVD_counterIn = 0;
