reading rom data program
Fabri
PostPosted: Mon Jan 28, 2008 8:55 am     Reply with quote
Hi ti all,
I decided to use SQTP programmer option to have in defined location unique data. SQTP write data in rom with retlw instruction. After program I found in location defined 0x3401 (mnemonic retlw 0x01). Which way I have to use to read data in rom location ? I use pIC16F630 and ccs. V3.249.
Thanks for help,
Regards,
Fabri
PostPosted: Mon Jan 28, 2008 11:24 am     Reply with quote
The RETLW instruction, is used to write a byte into a word in the program memory, which can then be called, to return this value. If the location where the data is being put, is inside the program memory (below 0x3FF), then something like:
int8 return_val(void) {
   int8 temp;
   #asm
   call 0x380 //changed to suit the required address
   movwf temp
   #endasm
   return(temp);
If instead the data was put at address 0x2100 to 0x21FF,then you cuold use the EEPROM read functions to access it.
The code above, is basically how the compiler accesses 'const' data tables in the ROM.
Fabri
PostPosted: Tue Jan 29, 2008 1:22 am     Reply with quote
Thanks Ttelmah,
I'ts a long time I didn't use assembler that I ever thought to use call instruction to read rom location.
Regards,
Fabri
