HOHOHAHA
INT_RB problem... |
Posted: Tue Jan 15, 2008 3:40 am |
I am trying to make an obstacle avoidance robo, using stepper (unipolar) motor ,,, and IR for the detection...I have connected the output of and LM324 (opamp) to the interrupt pins... the IR receiver are connected to the opamp , I have checked the hardware using LEDs ... when the objects detected by a specific IR the Leds go low ( leds connected to the output of the opamp. Now I have removed the LEDs and connected the 4 outputs of the opamps to the interrupt pins(RB4-RB7) ... but the interrupt seem not to work ...
I am using PIC16F877A ... and v4 CCS ...
What is the problem with my code... please help the newbie...
Thanks in Advance...
#include <16F877A.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES PUT //Power Up Timer
#FUSES WRT_50% //Lower half of Program Memory is Write Protected
#define T 20
byte last_b, port_b;
#int_rb
void rb_isr() {
byte changes;
byte port_b_Temp;
port_b_Temp==input_b();
port_b=(port_b_Temp & 0b11110000) ;
changes = last_b ^ port_b;
last_b = port_b;
if (bit_test(changes,4 )&& !bit_test(last_b,4)){
//b4 went low
printf("\nB4 Went low");
// enable_interrupts(INT_RB);
// enable_interrupts(GLOBAL);
return ;
if (bit_test(changes,5)&& !bit_test (last_b,5)){
//b5 went low
printf("\nB5 Went low");
return ;
if (bit_test(changes,6 )&& !bit_test(last_b,6)){
//b6 went low
printf("\nB6 Went low");
return ;
if (bit_test(changes,7 )&& !bit_test(last_b,7)){
//b4 went low
printf("\nB7 Went low");
return ;
void Move(void)
int16 i;
for(i=0;i<=24;i++) // turns 180
output_d(0b11001100);
delay_ms(T);
output_d(0b01100110);
delay_ms(T);
output_d(0b00110011);
delay_ms(T);
output_d(0b10011001);
delay_ms(T);
byte last_b_Temp;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,131,1);
setup_ccp1(CCP_PWM);
set_pwm1_duty(264);
setup_vref(FALSE);
// TODO: USER CODE!!
set_tris_a(0x00);
output_a(0x00);
set_tris_b(0xff);
//port_b_pullups (FALSE);
last_b_Temp=input_b();
last_b=last_b_Temp & 0b11110000;
set_tris_d(0x00);
clear_interrupt(INT_RB);
printf("\n hello world");
// scan();
Move();
//delay_ms(15);
//output_d(0b00000000);
//delay_ms(15);
Right_Ninety();
//delay_ms(15);
// Back();
//Back();
//Left_Ninety();
I tried a lot of options but ..the ISR seem not to work ... why ? I am really frustrated... |
D-Kens
Joined: 09 May 2005 Posts: 35 Location: Toulouse (France)
Posted: Tue Jan 15, 2008 3:51 am |
In the beginning of your interrupt routine, you wrote :
Code: | port_b_Temp==input_b(); |
where you meant
Code: | port_b_Temp=input_b(); |
Else, try just to increase a counter in your interrupt, for example, and print it on hyperterminal in your main(), just to check if you enter the interrupt or not... Depending on your answer, I'll look again at your code.
Regards,
Christophe. |
HOHOHAHA
Posted: Tue Jan 15, 2008 4:13 am |
Thanks .. I really overlooked it ...but the interrupt is still not working |
HOHOHAHA
Posted: Tue Jan 15, 2008 4:23 am |
Basically it works but not properly....though RB4 RB5 works fine but RB6 and RB7 give ambiguous results |
Posted: Tue Jan 15, 2008 4:24 am |
First, get rid of the 'enable_interrupts(GLOBAL)' lines in the ISR. Don't just REM them out, but remove them completely, and repeat after me _ on the PIC, you must never enable the global interrupt flag in the ISR_. This is a 'sure' way to make the code not work. One of the great 'never do' lines for the PIC. You had remmed the lines out, but remove them from existing completely!...
Now, the next stage, is to test what your hardware is actually doing. Verify that your processor can send a simple text message to the serial.
Then run a simple 'main' like:
int8 last_b, new_b;
last_b=new_b=input_b();
while (true) {
new_b=input_b();
if ((new_b^last_b) & 0b11110000) {
last_b=new_b;
printf("%2x/n/r",new_b);
My 'guess', is that you are going to find this does not work. The problem then is not the ISR, but almost certainly, that the signal levels being fed into the PIC, are not reaching the voltages needed to be detected reliably in one direction or the other. The PortB inputs, need the signal to get to below 0.8v, to be seen as a '0', and above 2v, to be seen as a '1' (assuming you are running off 5v). The LM324, should do this happily (should pull up to 3.5v, on a 5v supply, and down to only a few mV from the 0v rail), but (obviously), what it actually swings depends on the input circuit, and I'd suspect that it is nt swinginh far enough in one direction...
D-Kens
Posted: Tue Jan 15, 2008 4:28 am |
Well, you set the B4 to B7 pins to inputs, and you enable interrupts, so you should enter the routine. Did you try, as I said, to do something more simple ? Something like that :
Code: | long test=0 ;
#int_rb
void rb_isr() {
test++;
void main() {
setup_adc(ADC_OFF);
set_pwm1_duty(264);
setup_vref(FALSE);
set_tris_b(0xff);
while(1) { printf("Counter : %ld", test) ;
delay_ms(5000) ;
As I said, just to check if you enter the routine and that your problem is inside the routine, or if it is elsewhere.
Then, you should consider a debouncing solution for your inputs, else your counter will probably increase much more than expected at any change on the inputs. ![Confused](images/smiles/icon_confused.gif) |
HOHOHAHA
Posted: Tue Jan 15, 2008 9:35 am |
D-Kens wrote: | Well, you set the B4 to B7 pins to inputs, and you enable interrupts, so you should enter the routine. Did you try, as I said, to do something more simple ? Something like that :
#int_rb
void rb_isr() {
test++;
void main() {
setup_adc(ADC_OFF);
set_pwm1_duty(264);
setup_vref(FALSE);
set_tris_b(0xff);
delay_ms(5000) ;
Yes I am having debouncing problem... no solution for hardware .. the input is given by LM324... what should be the software solution ? |
Posted: Tue Jan 15, 2008 10:20 am |
Software solution, is to use one of the timers.
In the INT_RB routine, program this to trigger in perhaps 1mSec, enable this interrupt, disable int_rb, and exit the routine.
Then have an interrupt handler for the timer. In this, read the input again, and only if it still has the required 'change', then execute the required movement code. Disable the ter, and re-nable int_rb, before exiting.
This way, when an edge changes, it sets up the timer, and stops further changes triggering the interrupt. Then when the timer triggers, if the signal is still in the 'new' state, you respond to this, and go back to looking for further changes.
HOHOHAHA
Posted: Tue Jan 15, 2008 10:41 am |
I can't call a delay_ms() in isr... right ?? Can I call a function which will in turn call a delay ?? ... How can I exit from an isr without executing the later part of the code in isr... ? Your solution is nice but a bit tough for me to implement ... I am just a newbie.. |
Posted: Tue Jan 15, 2008 3:40 pm |
You can call a delay in an interrupt, but there are caveats.
If you add a separate #use delay statement in front of the interrupt declaration, then _separate_ timing code will be generated for the interrupt routine. This will prevent delays in the 'main' routines, from all having the interrupts disabled, which otherwise will cause massive response problems for all interrupts.
However, even with this done, remember that time spent in the interrupt handler, is time when nothing ese can basically occur. It may cause problems with serial reception, timing loops in the other code, etc. etc..
Basically, it is much nicer to always keep interrupts short. The delays needed for good keyboard debouncing, are so long, that they are likely to cause problems latter, if done in software inside the ISR...
As a further comment though, consider approaching everything differently. If you have a 'tick' interrupt from a timer, at something like (say) 50* per second, this can be used to provide basic timekeeping throughout the code, and if it checks the key bits (rather than using an interrupt to do this), and then if the keys are _still_ pressed on the next interrupt, 'records' the new key value, this provides debounce as well. This type of 'heartbeat' approach can be a much better approach to a lot of things...
HOHOHAHA
Posted: Thu Jan 17, 2008 10:22 am |
Ttelmah wrote: | Software solution, is to use one of the timers.
Can you please provide a working codeof the above concept ... delay in functions of ISR in not working properly ... if you ask I can put up my code here .. but it will be real pain for you to go through it ... I just messed it up... |
