xindy Guest
| ex_patg question.. |
Posted: Tue Mar 04, 2008 3:49 am |
just a question about the ex_patg example.. | Code: |
#include <16F877.h>
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
#define NUM_OUTPUTS 7
//NOTE: periods MUST be multiples of 400
//Periods are in microseconds
#define PERIOD_0 400
#define PERIOD_1 800
#define PERIOD_2 1600
#define PERIOD_3 2000
#define PERIOD_4 20000
#define PERIOD_5 64000
#define PERIOD_6 2000000
const long wave_period[NUM_OUTPUTS] = {
PERIOD_0/400, PERIOD_1/400, PERIOD_2/400, PERIOD_3/400,
PERIOD_4/400, PERIOD_5/400, PERIOD_6/400};
long counter[NUM_OUTPUTS] = {0,0,0,0,0,0,0};
int port_b_image;
// This interrupt is used to output the waveforms. The interrupt
// is automatically called ever 200us.
#INT_TIMER1
void wave_timer() {
int i;
set_timer1(0xFC4F); // sets timer to interrupt in 200us
output_b(port_b_image); // outputs the waveform
for(i=0; i<NUM_OUTPUTS; i++) // sets up next output for each pin
if((++counter[i]) == wave_period[i]) // if counter is expired
counter[i] = 0; // reset counter
if(bit_test(port_b_image,i)) // and set pin as needed
bit_clear(port_b_image,i);
bit_set(port_b_image,i);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); // setup interrupts
port_b_image=0; // initialize variable
while(TRUE); // loop forever
why is it that in the code above, it will interrupt every 200 us? i tried to do the math but i cant figure out how it arrives at 200 us.. please help.. thanks guys.. |
Posted: Tue Mar 04, 2008 5:52 am |
| Quote: | | why is it that in the code above, it will interrupt every 200 us? i tried to do the math but i cant figure out how it arrives at 200 us.. | At 20MHz every instruction clock cycle takes 20Mhz / 4 = 0.2us.
Timer1 in this program is setup to use no prescalers, i.e. it is dividing by 1 | Code: | setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); // setup interrupts
| This results in timer1 ticking with a speed of 1 tick every 0.2us.
An interrupt will be generated when the 16-bit timer overflows from 0xFFFF to 0x0000. Without modifications this would take 0.2us * 0x10000 = 13.1ms.
Now have a look at the start of the interrupt routine: | Code: | set_timer1(0xFC4F); // sets timer to interrupt in 200us
| The trick here is that timer1 is assigned a new start value which causes the next timer overflow to happen much sooner, after:
0x10000 - 0x0FC4F = 0x3B1 = 945 ticks
This is strange, I would have expected the math to come up with 1000. Most likely this deviation is there to compensate for the interrupt overhead; it takes about 40 instructions to save registers before your interrupt function is entered. I don't like the workaround here because the overhead is not a constant between processors and compiler versions, even another interrupt could cause large deviations. That's why I prefer to change this line to | Code: | | set_timer1( 1000 - get_timer1()); // sets timer to interrupt in 200us |
