NetBiosName
nazoa
NetBiosName
PostPosted: Mon Jan 14, 2008 6:19 am     Reply with quote
Can anyone give some ideas of where / how the NetBiosName parameter is set in the TCP/IP stack. What I am trying to do is to pass a name to the DHCP server to help users find the PIC board more easily in the network.
Thanks.
PostPosted: Mon Jan 14, 2008 9:29 am     Reply with quote
TCP/IP, is a transport layer. NetBIOS, is another layer _above_ this. You can have a system implementing TCP/IP, and NetBIOS, is not involved at all. The TCP/IP stack, sould have the 'host name', which is commonly the NetBIOS name, plus it's primary DNS Suffix (it doesn't have to be), but unless you are implementing NetBIOS over the TCP/IP layer, there will not be a NetBIOS name involved.
Do a search for RFC1001, which describes how NetBIOS is implemented over the TCP/IP transport.
nazoa
PostPosted: Mon Jan 14, 2008 10:15 am     Reply with quote
Thanks for your reply. Yeah, I did not make myself too clear. I using the 'TCP/IP' stack code that includes a NetBios module and my question really refers to this module.
Thanks again.
