write 2000 bytes in ROM and read it
PostPosted: Sat Jan 05, 2008 10:12 am     Reply with quote
How can I write data in ROM with #ROM and get it ?
thanks a lot
PostPosted: Sun Jan 06, 2008 5:35 pm     Reply with quote
Here is a short program that shows how to do it. This example only
stores 20 bytes in ROM, but you can add more bytes in the #rom
declaration. Here's the output of this program on a terminal window:
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
#include <18F452.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
#define DATA_ADDRESS 0x1000  // Start address for data
#define DATA_SIZE  20   // in bytes
#rom int8 DATA_ADDRESS =
0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19
void display_data(int32 rom_address)
int i;
int8 buffer[100];
read_program_memory(rom_address, buffer, DATA_SIZE);
for(i = 0; i < DATA_SIZE; i++)
    printf("%u ", buffer[i]);
display_data(DATA_ADDRESS);
PostPosted: Mon Jan 07, 2008 3:00 am     Reply with quote
However, 'caveat', this only applies to chips that support reading of their program memory (most of the 'newer' chips). You can't do this on some older chips, because the support is not there in the processor instructions. On these, it is actually basically 'impossible'.
John P
PostPosted: Mon Jan 07, 2008 9:27 am     Reply with quote
But is there a limit on how much data can be saved using a single #ROM directive, or the total amount of data which can be saved with multiple #ROM directives in the same program? I encountered a situation where I thought the compiler was refusing to accept more than a certain amount of data, but I solved the problem another way before I really reached an understanding of what was happening. I'd be curious to hear what limits exist, if any.
