simple conversion c->asm
Andrew-miksys
PostPosted: Thu Jan 10, 2008 11:25 am     Reply with quote
I'm trying do convert:
counter = 256*TMR1H + TMR1L;
to
#asm
movf   TMR1H,W
movwf high counter
movf   TMR1L,W
movwf low counter
#endasm
but compiler don't know operator 'low' and 'high'.
What is other way to do that?
PostPosted: Thu Jan 10, 2008 11:52 am     Reply with quote
Simplest way to find out is to compile your C code and than have a look at the list file (*.lst) to see what assembly the compiler generated.
I wouldn't use assembly at all. It is hard to read, not portable and there is no need to use it.
counter = make16(TMR1H, TMR1L);
This will compile to just as short assembly code as your example.
Andrew-miksys
PostPosted: Thu Jan 10, 2008 5:17 pm     Reply with quote
make16() doing exactly what I need! Thanks!
BDW here is 'compiler' optimalization Shocked
....................             counter = 256*TMR1H + TMR1L;
;  address of TMR1H is 0x0F
;  address of TMR1L is 0x0E
;  address of counter is 0x58,0x59
;  both in bank0
0321:  MOVF   0F,W
0322:  BSF    03.5
0323:  BSF    03.6
0324:  MOVWF  11
0325:  CLRF   10
0326:  BCF    03.5
0327:  BCF    03.6
0328:  MOVF   0E,W
0329:  BSF    03.5
032A:  BSF    03.6
032B:  ADDWF  10,W
032C:  BCF    03.5
032D:  BCF    03.6
032E:  MOVWF  59
032F:  BSF    03.5
0330:  BSF    03.6
0331:  MOVF   11,W
0332:  BCF    03.5
0333:  BCF    03.6
0334:  MOVWF  5A
0335:  BTFSC  03.0
0336:  INCF   5A,F
