Dietze Guest
Problems programming pic16F876A |
Posted: Wed Mar 26, 2003 3:38 am |
Hi all!
I´m using MPLAB v6.13 with the ICD 2 module and the PICDEM 2 plus Demo board with the CCS PCM-Compiler. My Code is compiling normally, but when I´m trying to program, (Debugger - Programm) it programs but then there always comes the error message(Target not in debug mode ....). I tried all the 3 possible Failures (in the MPLAB Help e.g. enable background debug...)but none of these seems to be the reason. Must I change something in my programm code or is there another reason, maybe CCS PCM isn`t working with one of my components?
Thanks for your help
Dietze
Original Post ID: 13074 |
Dietze Guest
Re: Problems programming pic16F876A |
Posted: Wed Mar 26, 2003 6:33 am |
:=Hi all!
:=I´m using MPLAB v6.13 with the ICD 2 module and the PICDEM 2 plus Demo board with the CCS PCM-Compiler. My Code is compiling normally, but when I´m trying to program, (Debugger - Programm) it programs but then there always comes the error message(Target not in debug mode ....). I tried all the 3 possible Failures (in the MPLAB Help e.g. enable background debug...)but none of these seems to be the reason. Must I change something in my programm code or is there another reason, maybe CCS PCM isn`t working with one of my components?
:=Thanks for your help
:=Dietze
Heard there is probably a ground loop in the ICD2 module and this is the reason why it doesn`t work. Can somebody tell me how to fix it?
Original Post ID: 13081 |
Matthew Guest
Posted: Wed Mar 26, 2003 10:13 pm |
:=:=Hi all!
:=:=I´m using MPLAB v6.13 with the ICD 2 module and the PICDEM 2 plus Demo board with the CCS PCM-Compiler. My Code is compiling normally, but when I´m trying to program, (Debugger - Programm) it programs but then there always comes the error message(Target not in debug mode ....). I tried all the 3 possible Failures (in the MPLAB Help e.g. enable background debug...)but none of these seems to be the reason. Must I change something in my programm code or is there another reason, maybe CCS PCM isn`t working with one of my components?
:=:=Thanks for your help
:=:=Dietze
:=Heard there is probably a ground loop in the ICD2 module and this is the reason why it doesn`t work. Can somebody tell me how to fix it?
In version 5.X you need to make sure that the "Enable Debug Mode" box is NOT ticked as this I was told creates a similar problem.
Original Post ID: 13116 |
Dietze Guest
Posted: Fri Mar 28, 2003 1:33 am |
:=:=:=Hi all!
:=:=:=I´m using MPLAB v6.13 with the ICD 2 module and the PICDEM 2 plus Demo board with the CCS PCM-Compiler. My Code is compiling normally, but when I´m trying to program, (Debugger - Programm) it programs but then there always comes the error message(Target not in debug mode ....). I tried all the 3 possible Failures (in the MPLAB Help e.g. enable background debug...)but none of these seems to be the reason. Must I change something in my programm code or is there another reason, maybe CCS PCM isn`t working with one of my components?
:=:=:=Thanks for your help
:=:=:=Dietze
:=:=Heard there is probably a ground loop in the ICD2 module and this is the reason why it doesn`t work. Can somebody tell me how to fix it?
:=In version 5.X you need to make sure that the "Enable Debug Mode" box is NOT ticked as this I was told creates a similar problem.
Thank you but this isn´t realy the problem! Because you can only use the ICD2 with the v6.xx and I think it´s obvious that you enable debug mode when you want to debug!
Original Post ID: 13176 |
