help need to display numbers on static LCD
deepakomanna
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Mon Dec 31, 2007 7:48 am     Reply with quote
Dear Sir,
here i am using 16f913, MPLAB 7.5 Ver. & CCS PCM C Compiler, Version 3.249, 34534.
In this i am displaying numbers from rightmost side.The number is incrementing in every 1 sec.Also I have to blink a symbol as like "Dumbbell shped" in every 1 sec. The symbol is at left side. Here i/p is frequency (297 Hz)which is connected at pin no 16 (RC5).In the ccp1 interrupt i am incrementing 1 variable to count 1 sec. Once it reaches to 1 sec count then it will compliment the flag "BLINK_DUMBEL". this flag is used for blinking the symbol. & increment the number. which will display on Static LCD.
The number is incrementing properly but the Symbol is not blinking in every 1 sec. sometimes it wll blnk & sometimes not blink.
Here is my code,Plz help.
#include<16F913.h>
#fuses INTRC_IO,NOWDT,PUT,NOMCLR,NOPROTECT,NOCPD,BROWNOUT,NOIESO,NOFCMEN   //external MCLR bcz of MPLAB ICD2
#use delay(clock=8000000)
//                                 LCD Configuration                                   //
// Digit segments    A              B              C              D              E              F              G           DP
//                         b7             b6             b5             b4             b3             b2            b1             b0
#define DIGIT1  COM0+0,   COM0+1,   COM2+1,   COM3+0,   COM2+0,   COM1+0,   COM1+1,   COM3+3      // DISPALYS FROM RIGHT SIDE
#define DIGIT2  COM0+2,   COM0+3,   COM2+3,   COM3+2,   COM2+2,   COM1+2,   COM1+3               // DISPALYS FROM RIGHT SIDE
#define DIGIT3  COM0+4,   COM0+5,   COM2+5,   COM3+4,   COM2+4,   COM1+4,   COM1+5               // DISPALYS FROM RIGHT SIDE
#define DIGIT4  COM0+6,   COM0+7,   COM2+7,   COM3+6,   COM2+6,   COM1+6,   COM1+7                  // DISPALYS FROM RIGHT SIDE
#define DIGIT5  COM0+8,   COM0+9,   COM2+9,   COM3+8,   COM2+8,   COM1+8,   COM1+9                  // DISPALYS FROM RIGHT SIDE
#define DIGIT6 COM0+13,   COM0+11,   COM2+11,   COM3+13,   COM2+13,   COM1+13,   COM1+11                  // DISPALYS FROM RIGHT SIDE
#define DIGIT7 COM0+12,   COM0+14,   COM2+14,   COM3+12,   COM2+12,   COM1+12,   COM1+14                  // DISPALYS FROM RIGHT SIDE#define VLCD_ENABLE 0x10
#define DUMBEL COM3+14
//character                     0         1        2         3        4        5        6         7       8        9
byte const Digit_Map[10] = {0xFD,0x61,0xDB,0xF3,0x67,0xB7,0xBF,0xE1,0xFF,0xF7};
byte lcd_pos;
byte segments;
void init_CPU();
int32 number;
int16 sec_counter;
int1 BLINK_DUMBEL ;      // this flag for blinking the DUMBEL SYMBOL
void lcd_putc(char c)
 if(c=='\f')
     lcd_pos=0;
else {
           if((c>='0')&&(c<='9'))
                  segments=Digit_Map[c-'0'];
               segments=0;
      switch(lcd_pos)
          case 1:  lcd_symbol(segments,DIGIT7); break;     // fill 1s place
          case 2:  lcd_symbol(segments,DIGIT6); break;     // fill 1s place
         case 3:  lcd_symbol(segments,DIGIT5); break;      // fill 10s place
              case 4:  lcd_symbol(segments,DIGIT4); break;     // fill 100s place
             case 5 : lcd_symbol(segments,DIGIT3); break;     // fill  1000s place
              case 6 :
                        if(number<10)
                           segments = Digit_Map[0];
                        lcd_symbol(segments,DIGIT2); break;      // fill  10000splace
                case 7 :
                    if(BLINK_DUMBEL == 1)
                       lcd_symbol(segments,DUMBEL);    // fill  100000s place
                       lcd_symbol(segments,0);    // fill  100000s place
                    lcd_symbol(segments,DIGIT1);    // fill  100000s place
 lcd_pos++;
#int_ccp1
void ccp1_isr(void)
sec_counter++;
if(sec_counter >=298)   // 1sec == 298 count
      BLINK_DUMBEL =~BLINK_DUMBEL;      // compliment flag for DUMBEL SYMBOL.
   //   if(BLINK_DUMBEL == 1)
           //   lcd_symbol(segments,DUMBEL);    // fill  100000s place
      sec_counter = 0;
      number++;
      if(number == 999999)
         number = 0;
void  init_CPU()
/**************  PORT SETTINGS ****************/
   PORT_B_PULLUPS(0X00);
   SET_TRIS_A(0XC0);         //External Oscillator  i/p OSC1 & OSC2
   SET_TRIS_B(0X00);
   SET_TRIS_C(0X27);         //VLCD 1,2,3 i/p,FREQ i/p @ Pin no 16.
   SET_TRIS_E(0X08);         // RE3 i/p for programming the device.
/*************** LCD SETTINGS ********************/
   SETUP_LCD( LCD_MUX14 |LCD_INTRC|VLCD_ENABLE, 2);
/****************  COMPARATOR SETTINGS  ***************/
   SETUP_COMPARATOR(NC_NC_NC_NC);
/****************  INTERRUPT SETTINGS  *****************/
ENABLE_INTERRUPTS(GLOBAL);
set_timer1(0);
setup_ccp1(CCP_CAPTURE_RE);       //Capture on rising edge
clear_interrupt(INT_CCP1);
enable_interrupts(INT_CCP1);
setup_timer_1(T1_EXTERNAL | T1_DIV_BY_1 | T1_CLK_OUT);
init_CPU();
number = 0;
            printf(lcd_putc,"\f%7lu",number);
Thank You,
With Best Regards,
Deepak.
