trouble: for() iteration using INT32 variables
ivanperino
PostPosted: Wed Jan 02, 2008 7:11 am     Reply with quote
I`m working with a pic 16f88 on a CCS 4.023 and I have trouble when I use "for()" iteration with int32 variable but it works right if I do it with a "while()" iteration.
The piece of code that doesn`t work is:
#include <C:\Archivos de programa\CCS4\Devices\16F88.h>
#device ADC=10
#fuses NOWDT,INTRC_IO, PUT, NOBROWNOUT, NOLVP, NOWRT, NOPROTECT, MCLR
int32 aux_d;
int8 aux_dato;
for(aux_d=0x00000000; aux_d <= 0x0003ffff; dir++){
aux_dato = read_ext_eeprom(aux_d);
printf("%lx -- %x\n\r",aux_d,aux_dato);
if(aux_dato != 0xff){
aux_d = 0xffffffff;
dir = aux_d + 1;
It run indefinitely, the statments printf arenĀ“t necessary but they help me to debug the program. printf shows to me that for() doesn't break out.
In the other hand, the next piece of code runs right:
#device ADC=10
int32 aux_d;
int8 aux_dato;
aux_d=0x0003ffff;
while((0xff == aux_dato) & (aux_d != 0)){
aux_d--;
dir = aux_d + 1;
using while() iteration, it works ok.
What is happening? May be a Compiler bug?
Thank you to everybody.
Wayne_
PostPosted: Wed Jan 02, 2008 8:02 am     Reply with quote
The condition for leaving the for loop will never be met because you are NOT incrementing aux_d.
no idea why you are incrementing dir or why it is there!
in the while loop you are actually going backwards through the addresses, why are you not doing the same in the for loop ?
