Warp13 and V4
Kieran
Warp13 and V4
PostPosted: Tue Nov 20, 2007 5:59 am     Reply with quote
I still use my Warp13 for programming where there is no ICD.
I have updated to V4 and can't get the user defined tool to work with the programmer.
Can anyone help with the command line syntax?
BLL
PostPosted: Tue Nov 20, 2007 8:21 am     Reply with quote
If you are interested, I have written a program called CCS2Warp.exe which will correctly start Warp13 from within the CCS compiler, because, as you say, it can't be done with the compiler as it stands.
email to brian.lonnon@tiscali.co.uk
Cheers
Brian
Joan_
Re: Warp13 and V4
PostPosted: Thu Dec 27, 2007 8:08 pm     Reply with quote
Guys,
do you know if newfoundelectronics is still on-line? I'm using this programmer for 5 years and on those days webpage seems to be unnavaliable.
Regards,
Joan
BLL
Warp13 and v3 or 4
PostPosted: Fri Dec 28, 2007 4:23 am     Reply with quote
I use the following:
"k:\picc\v3\ccs2warp.exe" %H -%D k:\picc\warp13\warp13.exe
The ccs2warp.exe program massages what the compiler outputs so the warp13 can understand it and get both the device type and the hex file from the compiler.
I can supply CCS2Warp.exe on request if anyone wants it.
Brian
