Franck26 Guest
Multiple Compilation Units + Debugger |
Posted: Sat Dec 29, 2007 3:53 pm |
Hi everybody,
I have a problem to use the "Multiple Compilation Units" with PCD and IDE 4.064.
I'm using a very short program with just 2 C files: "Main.c" and "Nothing.c".
The program is working when I'm not using the "Multiple Compilation Units" (I include "Nothing.c" in "Main.c"). I can compile, load and debug the prog on my target.
To use the "Multiple Compilation Units" I include "Nothing.H" in "Main.c" and I check "Multiple Compilation Units" and "Link Separately" in "Project Option".
The result is that I can compile, and load the prog, but when I click on "GO" to debug, I get the error message:
"ICDWarn0015: Program memory has changed since last program operation? Continue with Debug operation?".
And the prog is resetting...
I've tried to find a solution for 1 week now, and I'm still at the same point. So if you have an idea, please help me.
I can give the files if necessary.
Thanks a lot and happy New Year.
Franck. |
