PIC12F683 problem with WDT and Timer0?
nmeyer
PostPosted: Thu Dec 20, 2007 12:38 pm     Reply with quote
I am trying to run a simple program that fires a output after a set time interval. I am using int_rtcc to count seconds, which is code that i have used else where inother pics with good succes. For some reaston it seems that if the Wdt is enabled, the timer0 does not work. if i turn it off, it times but not correctly. It has to be something in the set up, but i can not find what it is. Does anyone have suggestions? Thanks
V4.062
#include <12F683.h>
#device adc=10
#use delay(clock=2000000,RESTART_WDT)
#fuses WDT,INTRC_IO, PUT, MCLR, NOBROWNOUT, NOCPD, NOPROTECT
#include <math.h>
#use fast_io(A)
#define  GPIO1    PIN_A0
#define  LED2     PIN_A1
#define  time_in  PIN_A2
//#define  time_in  PIN_A3
#define  trn      PIN_A4
#define  lbo      PIN_A5
#define INTS_PER_SECOND  976
char  int_count,loop;
long  time1,time2,time3,seconds,voltage,hour,day,minute;
#int_rtcc
void clock_isr(void)
   if(--int_count==0)                     //decrement counter until 0
      ++seconds;                          //count up seconds
      int_count=INTS_PER_SECOND;          //reset counter
      if (seconds>=65000)
         seconds=65000;
   setup_oscillator(osc_2mhz);
   //setup_adc_ports(sAN2);
   //setup_adc(ADC_CLOCK_DIV_16);
   setup_wdt(WDT_ON);
   //setup_wdt(WDT_72MS | WDT_ON);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
   set_rtcc(0);
   enable_interrupts(INT_RTCC);
   //setup_timer_1(T1_DISABLED);
   set_tris_a(0b00101111);
   output_low(trn);                    //shut off solenoid
   int_count=INTS_PER_SECOND;          //used for timer
   seconds=0;                          //clear out variable
   hour=0;                             //clear low volage counter for seconds
   day=0;                              //clear out day counter
   minute=0;
   time1=20;                            //counter for time
   loop=1;
   voltage=0;
   //set_adc_channel(2);
   //delay_ms(1000);
   while (TRUE)
      //voltage=read_adc();
      while(loop=1)
      /*if(voltage>=1010)
         output_high(trn);
         output_low(trn);
      if(seconds>=time1)
         output_high(trn);
         restart_wdt();
         output_low(trn);
         loop=0;
         //seconds=0;
      while (loop==0)
         output_low(trn);
PostPosted: Thu Dec 20, 2007 12:46 pm     Reply with quote
char int_count, loop;
int_count = INTS_PER_SECOND
You're loading a 'char' with a value greater than 255.
nmeyer
PostPosted: Thu Dec 20, 2007 1:08 pm     Reply with quote
Thanks for catching that. Still something seems to be conflicting with the wdt. if it is off, i seem to be able to run close to where i want. with it on, it does not work at all.
PostPosted: Thu Dec 20, 2007 1:24 pm     Reply with quote
The WDT has a 16-bit prescaler. In addition to that, there is another
divider that can optionally be assigned as a WDT post-scaler or as
a pre-scaler for Timer0.
I don't have time to figure out the correct setup right now. I have to
do things at work. Maybe later.
nmeyer
PostPosted: Thu Dec 20, 2007 2:00 pm     Reply with quote
Yes, that is what i was pursuing. I have not found the correct set up yet, but i am testing with the wdt off now and it seems to be running ok. I will look into it some more. Thanks
PostPosted: Sun Dec 23, 2007 4:18 pm     Reply with quote
I had some more time to work on this today. I made a test program
that does RTCC interrupts at 976 Hz, and it also runs the Watchdog timer
at a period of 69 ms. I didn't put in any code to restart the WDT because
I wanted it to do a reset, so I could measure the rate.
#include <12F683.h>
#fuses INTRC_IO, NOWDT, MCLR, PUT, BROWNOUT
#use delay(clock=2000000)
#int_rtcc
void rtcc_isr(void)
// Create a short pulse so we can see the RTCC
// interrupt frequency on Pin A2 on a scope.
output_high(PIN_A2);
delay_us(10);
output_low(PIN_A2);
// Create a short pulse so we can see the WDT
// restart frequency on Pin A5, on a scope.
output_high(PIN_A5);
delay_ms(1);
output_low(PIN_A5);
setup_wdt(WDT_ON | WDT_TIMES_4);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_2);
