Matthew Aurand
Interrupts and SPI Slaves |
Posted: Thu Dec 20, 2007 10:54 pm |
I have a few basic questions for which I have had a hard time trying to find answers to.
First, I have been using software spi support (spi_xfer()) for a setup in which I have two PIC's. One is the master (and is working fine) and the other is the slave to the master. The slave spi_xfer function works fine when I am only transferring one variable, but when I have several variables to pass (therefore I have several spi_xfers execute consecutively) the slave function always hangs as if it has not received enough clocks to complete the transfer. I have added extra clock outs from the master to see if this is the case, but it does not help. I am passing int8 vars, and all samples (according to diagnostic pin analysis) are where they should be. I am quite confused and wish the documentation for this function was a bit more descriptive. Any ideas? I am sure it is something simple, what is obvious to check (I must have missed something easy...).
Second, I am a little confused about interrupts. If disable_interrupt(xxx) is called within that ISR(xxx), what does that mean? If I disable an interrupt of higher priority within another ISR, can the higher priority interrupt still fire? I assume not, but that is not clear. Why exactly should you clear the interrupt flags?
I really have exhausted the resources I have here, and am desperately trying the learn the fundamentals. The manual and websites I have looked at don't really make it very apparent. They are either remarkably trivial and don't address my questions or they are over my head.
Can anyone point me in the right direction?
I really appreciate any advice,
-Matt _________________ -Matthew A. Aurand |
Posted: Fri Dec 21, 2007 12:47 am |
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=31165
If that doesn't help, then:
1. Post your compiler version.
2. Post very short, but complete test programs for the master and
slave PICs that demonstrate the problem. |
Posted: Fri Dec 21, 2007 9:25 am |
For the interrupt part, you need to understand the suprisingly large number of parts associated with the 'interrupt'.
For each interrupt source, there is an interrupt 'flag', and interrupt 'enable', (and for the 18F chips, a 'priority' flag as well). Then globally, there is another interrupt 'enable' for all the interrupts (and a second for the high priority ones on the 18F chips).
To actually trigger an interrupt, the 'flag' has to be set, the 'enable' has to be set, and the corresponding global 'enable' has to be set.
When the interrupt triggers, this _automatically_ turns off the corresponding global enable.
When the hardware event corresponding to an interrupt source occurs, the interrupt 'flag' is automatically set. Once set, this remains set, till cleared (and also, till the event causing it is cleared, so for RB changed interrupts, you must also read the port as well).
So the sequence is:
Hardware event happens.
Interrupt flag is set.
If both the interrupt enable is set, and the corresponding global enable is set, the global interrupt handler is called at the start of the _next_ program instruction.
The global handler, then saves the registers, and _polls_ the interrupt flags, in the order defined by the order in which they were defined, _or_ as specified in the #priority statement. For the first interrupt, which has both it's flag, and it's enable set, the corresponding 'handler' sub is called. This must clear the hardware event involved (read a byte for a serial routine, read the port for the B changed interrupt etc..). Then the compiler automatically adds the code at the end of the routine, to clear the _flag_. The _enable_, is distinct, and may also need to be cleared (so for example, in a 'serial transmit' interrupt, if no more bytes are waiting to be sent, then the enable will need to be cleared, or the interrupt will continuously retrigger (since the transmit buffer is empty). It'd need to be turned back on, as soon as more data becomes available to send.
The subroutine then returns to the global handler, which restores the registers, and performs a 'retfie' instruction. This returns to the point where the interrupt triggered, _and automatically resets the 'global' enable bit_ after the return.
The 18F 'high priority' interrupts behave exactly the same way, except that their global bit, also disables the low priority interrupts, while the enable for the low priority interrupts, does not disable the high priority ones.
So disabling the interrupt inside a routine, makes perfect sense. It doesn't stop the other interrupts _flag_ bit from setting, but does stop the handler from being called. If latter the interrupt is again enabled, and a trigger has occured in the meantime, since the flag has been set, it'll be called straight away.
One 'must never be done' thing, is to enable/disable the _global_ enable inside an interrupt. The reason is that enabling it, can ptentially allow another interrupt to trigger inside the routine (causing problems with 're-entrancy'), while disabling it, is pointless, since it is already disabled by the hardware...
For the SPI, I posted some routines here in the past. Unfortunately, the inbuilt routines, are not really designed for use with interrupts, especialy for the 'slave' and while they can be made to work, it doesn't make good use of the SPI hardware...
Matthew Aurand
Posted: Fri Dec 21, 2007 11:41 am |
Wow, thanks guys!
PCM programmer: I read the thread you linked to and it is indeed a very similar problem to mine. Can you elaborate on reading the spi port between writes? I need to call a read function between sends? I know that the port sends/receives at the same time, but I am having the slave just send 0x00 per write from the master. The master is generating all clocks for the consecutive transfers, but for some reason the slave is not interpretting them properly.
Ttelmah: GREAT! So I always need to clear the interrupt flag after servicing it, or it will continuously trigger. This explains some problems I was having with the ext interrupt. Then I need to re-enable global. Thanks so much for your time! _________________ -Matthew A. Aurand |
Posted: Fri Dec 21, 2007 11:54 am |
