FRC_PLL16
paulholland
FRC_PLL16
PostPosted: Sat Dec 15, 2007 2:46 pm     Reply with quote
How to use RFC_PLL16 in dsPIC30 using #fuses FRC_PLL16 ??.. I get compiler error while this is a valid command according to manual !
PostPosted: Sun Dec 16, 2007 12:36 am     Reply with quote
Look near the beginning of the .H file for your PIC. It shows all the fuse
settings that can be used with your PIC See if that fuse is in the list.
Also check the spelling. In your post, you spell it two different ways.
If you have full CCS IDE, then bring up that PIC in the Device Editor.
Look at the fuse settings in the upper right corner of the window.
See if your desired fuse is in the list. Screen shot of Device Editor:
http://www.ccsinfo.com/images/content/device_editor.gif
paulholland
FRC_PLL16
PostPosted: Thu Dec 20, 2007 10:04 am     Reply with quote
Hi, Thanks but I have solved the problem. CCS has a bug here since I tried all and finaly did program the config register myself to solve it. One of the 1 billion bugs in CCS. The product sucks but my client wants me to use it, unfortunately.
