Ramey
PIC18F4450 and USB |
Posted: Tue Dec 18, 2007 5:58 pm |
I can compile the CCS example ex_usb_kbmouse2.c out of the box without problem. When I make the following change:
replace
#include <18F4550.h>
with
#include <18F4450.h>
I get Code: |
Clean: Deleting intermediary and output files.
Clean: Deleted file "ex_usb_kbmouse2.ERR".
Clean Warning: File "C:\Projects\bigkeys\Code\ex_usb_kbmouse2.o" doesn't exist.
Clean: Done.
Executing: "C:\Program Files\PICC18\Ccsc.exe" "ex_usb_kbmouse2.c" +FH +DF +LN +T -A +M +Z +Y=9 +EA
>>> Warning 215 "C:\PROGRA~1\PICC18\drivers\pic18_usb.h" Line 165(1,1): Undefined identifier USB_EP3_TX_SIZE
>>> Warning 215 "C:\PROGRA~1\PICC18\drivers\pic18_usb.h" Line 165(1,1): Undefined identifier USB_EP3_RX_SIZE
>>> Warning 215 "C:\PROGRA~1\PICC18\drivers\pic18_usb.h" Line 165(1,1): Undefined identifier USB_EP4_TX_SIZE
>>> Warning 215 "C:\PROGRA~1\PICC18\drivers\pic18_usb.h" Line 165(1,1): Undefined identifier USB_EP4_RX_SIZE
>>> Warning 215 "C:\PROGRA~1\PICC18\drivers\pic18_usb.h" Line 165(1,1): Undefined identifier USB_EP5_TX_SIZE
>>> Warning 215 "C:\PROGRA~1\PICC18\drivers\pic18_usb.h" Line 165(1,1): Undefined identifier USB_EP5_RX_SIZE
>>> Warning 215 "C:\PROGRA~1\PICC18\drivers\pic18_usb.h" Line 165(1,1): Undefined identifier USB_EP6_TX_SIZE
This doesn't seem right - there might be more changes required to make it work, but it should at least compiler - Or shouldn't it? Any help appreciated.
Robet Ramey |
Posted: Wed Dec 19, 2007 12:50 pm |
I tested it with vs. 4.064, and it doesn't compile. It gives the same
errors. CCS has some #if and #elif statements in pic18_usb.c
to configure the code for the 18F4450. Apparently, it needs to be
fixed for the Ex_usb_kbmouse2.c example. I suggest that you
contact CCS Tech support and ask them about it. |
