spi_xfer byte order in multi-byte commands / responses?
aefelgate
PostPosted: Mon Dec 17, 2007 7:05 pm     Reply with quote
I am using the CCS compiler's built-in spi_xfer() function to transmit 16 bit and 24 bit commands to a device.
What is the BYTE order required? Can anybody answer this simple question?
e.g. I wish to transfer the following bytes, in the following order:
0x01 0x00 0x00
I create a 32-bit variable, and us it as follows:
#use spi(MASTER,
DI=PIN_A3,
DO=PIN_A5,
CLK=PIN_A2,
ENABLE=PIN_C0,
ENABLE_ACTIVE=0,
MODE=3,
BITS=32,
LSB_FIRST,
STREAM=SPI_STREAM)
int32 spi_data = 5;
int32 spi_xfer_status = 0;
// Send 0x05 0x00 0x00
spi_xfer_status = spi_xfer(SPI_STREAM, spi_data, 24);
Is this correct? Or, does it need to be 0x05000000?
Or 0x00050000
I am sending data LSB FIRST, but what is the byte order???
Also, I am assumin the response, spi_xfer_status in my code above, will be returned with the byte order mapped in the same way as the command?
The CCS compiler manual and examples only give a single byte example when using the spi_xfer() command; there needs to be a multi-byte example, which would then easily clear up this confusion.
PostPosted: Tue Dec 18, 2007 12:58 am     Reply with quote
You can find answer from the .LST file, after compiling your test program:
Here, the LSB (5) is put into address 0x21:
... int32 spi_data = 5;
004D:  MOVLW  05
004E:  MOVWF  21
004F:  CLRF   22
0050:  CLRF   23
0051:  CLRF   24
Then the LSB is moved into RAM address 0x29, before the program
jumps to the SPI library code at ROM address 0004.
... // Send 0x05 0x00 0x00
... spi_xfer_status = spi_xfer(SPI_STREAM, spi_data, 24);
0056:  MOVF   24,W
0057:  MOVWF  2C
0058:  MOVF   23,W
0059:  MOVWF  2B
005A:  MOVF   22,W
005B:  MOVWF  2A
005C:  MOVF   21,W
005D:  MOVWF  29    // LSB is now in 0x29
005E:  MOVLW  18
005F:  MOVWF  2D   // Bit count (24) is in 0x2D
0060:  GOTO   004
// Then the LSB byte (05) is shifted out first.
... #use spi(MASTER,DI=PIN_A3,DO=PIN_A5,CLK=PIN_A2,
ENABLE=PIN_C0,ENABLE_ACTIVE=0,MODE=3,BITS=32,
LSB_FIRST,STREAM=SPI_STREAM)
0004:  BSF    03.5
0005:  BSF    05.3
0006:  BCF    05.5
0007:  BCF    05.2
0008:  BCF    03.5
0009:  BSF    05.2
000A:  BCF    20.0
000B:  MOVF   20,W
000C:  BSF    03.5
000D:  MOVWF  07
000E:  BCF    03.5
000F:  BCF    07.0
0010:  MOVF   2D,W
0011:  MOVWF  2E
0012:  BCF    05.2
0013:  BTFSS  29.0  // Test Bit of the LSB.
0014:  BCF    05.5  // Set SDO to the same value.
0015:  BTFSC  29.0
0016:  BSF    05.5
0017:  RRF    2C,F  // Then rotate all four data bytes
0018:  RRF    2B,F  // right by 1 bit position.
0019:  RRF    2A,F
001A:  RRF    29,F
001B:  BSF    05.2
001C:  RRF    7A,F
001D:  RRF    79,F
001E:  RRF    78,F
001F:  RRF    77,F
0020:  BTFSS  05.3
0021:  BCF    7A.7
0022:  BTFSC  05.3
0023:  BSF    7A.7
0024:  DECFSZ 2E,F   // Decrement bit count.
0025:  GOTO   012    // Loop until all bits are sent.
// (Remainder of library code is not shown)
aefelgate
PostPosted: Tue Dec 18, 2007 11:45 am     Reply with quote
Thanks for clearing this up. Now that I understand how the compiler orders the bits and bytes I know that is not the problem.
