deepakomanna
Interrupt for RB6(pin 27) of 16f913 |
Posted: Sat Dec 15, 2007 3:28 am |
Dear Sir,
here i am using 16f913, MPLAB 7.5 Ver. & CCS PCM C Compiler, Version 3.249, 34534.
i want to use IOC only for RB6 pin 27 for this my defined statements are,
Code: | /*********************************/
read_port = input_a();
clear_interrupt(INT_RB);
enable_interrupts(INT_RB);
But i checked header file,Only defined statement is
Quote: | #define INT_RB 0x0B08 |
So if i want to enable interrupt only for RB6,how should i define ?
Actually To this pin i have connected a push button switch,So if i pressed the switch, the interrupt will follow
IOC isr.In this isr i am clearing all EEPROM LOcations.My defined statements are,
Code: | #int_rb
void ioc_isr(void)
int8 read_port,clear_ee;
delay_us(10);
for(clear_ee = 0; clear_ee>=255;clear_ee++)
write_eeprom(clear_ee,0);
read_port = input_b();
awaiting for your reply _________________ Thank You,
With Best Regards,
Deepak. |
Posted: Sat Dec 15, 2007 6:09 am |
First comment. You should tweak your interrupt code a little:
#int_rb
void ioc_isr(void) {
//Why delay?. - the code itself takes about 1 second... delay_us(10);
read_port=input_b();
if ((read_port & 0b01000000) ==0) {
//The problem is that the 'changed' interrupt, will trigger on both edges
//of the signal on the pin, and also the signal may change several times
//(bounce). Hence you need to ensure that the code is only called on
//one edge - I check for the _falling_ edge (assuming you have a
//pullup, and a switch to ground. Unless you can be _absolutely_ sure
// the button will be released before the code is complete, you need
//this extra test.
read_port=input_b(); //extra read here, will ensure the above does
//happen, if the button _has_ released.
In your main 'setup' code, you don't show the]
'enable_interrupts(GLOBAL)' statement. This too is needed.
Now, on later compilers, the other piece of setup, is available 'pre done', but on your version, you need:
#byte IOCB=0x96
IOCB=0b01000000; //enable changed interrupt on B6 only
read_port=input_a();
