getc array send only one character
saee
PostPosted: Mon Dec 03, 2007 6:29 am     Reply with quote
when use getc function to array , with using putc ,specific array index sholud be send to the pc
for example
from pc : send 12345 to pic 16f877a
pic: read array ,getc, then send it for example second data,2, w
how???
c[]=getc;//read 12345
putc(c[1]);//send only 2
but how ??
this is not true
SherpaDoug
PostPosted: Mon Dec 03, 2007 8:41 am     Reply with quote
I don't really understand your question, but this may help.
getc() and putc() normally only handle one byte, or character at a time. An odd addition to standard C in CCS is that if you give putc() a multi-byte argument the compiler calls putc() once for each byte. This can not work with getc() as the compiler has no way to know how many bytes are out there.
Maybe you should use string functions instead of byte (character) functions?
PostPosted: Mon Dec 03, 2007 2:11 pm     Reply with quote
Look at the get_string() function, to get a string. It's in this CCS file:
c:\Program Files\picc\Drivers\Input.c
Also look at the puts() function, to send a string.
Storic
Re: getc array send only one character
PostPosted: Mon Dec 03, 2007 2:32 pm     Reply with quote
putc(c[0]);//will send 1
when I was first learning C, I got confused with the fact C uses '0' as a valid count.
for(i=0; i<=4; i++)
   putc(c[i]);
should give you 12345 c[0],c[1],c[2],c[3],c[4],
What has been learnt if you make the same mistake? Wink
yesahycs
dun use putc
PostPosted: Wed Dec 05, 2007 3:47 am     Reply with quote
try printf instead of putc.
ex:
int i;
for(i=0; i<=4; i++)
printf("%d",c[i]);
