3 Minute interrupt required
SerialGmr8
PostPosted: Mon Dec 03, 2007 12:09 am     Reply with quote
Greetings all,
im trying to get an approximate interupt rate of one second on timer0, using ccs compliler version 4.059, to a pic16f877a target chip running at 20Mhz
#include <16F877A.h>
//   The cycle time will be (1/clock)*4*t2div*(period+1)
//   clock=20Mz and period=6144
//   (1/20Mz)*4*1*6145=1.23MS (814Hz)
#int_TIMER0
int16 counter = 0;
void TIMER0_isr()
  counter++ ;
  if(counter == 814)
       counter = 0;
      OneSec = 1;
   setup_timer_0(T2_DIV_BY_1,6144,1);
not having much luck here. Ideally, I want to get to an interupt every three minutes to control a thermostat, but apparantly, im a long ways from there. Would greatly appreciate some assistance.
best regards
PostPosted: Mon Dec 03, 2007 1:22 am     Reply with quote
The CCS manual says setup_timer_0() only has one parameter, called 'mode':
setup_timer_0 (mode)
Look in the 16F877A.H file to see the list of constants that may be
used as the mode parameter. They all begin with 'RTCC'.
PostPosted: Mon Dec 03, 2007 3:39 am     Reply with quote
#int_TIMER0
int16 counter = 0;   <-- Don't do this !!!
void TIMER0_isr()
Do not insert anything between the interrupt declaration (#int_xxx) and the function name. Maybe the compiler is not generating an error message but that doesn't mean it is correct syntax.
SerialGmr8
PostPosted: Mon Dec 03, 2007 5:57 am     Reply with quote
Thanks guys. i've updated my code to be similar to one of the examples with ccs. but this still doesnt work.
when i get my first three minute interrupt, would i have to restart a counter or something ?
#define INTS_PER_SECOND 76     // (20000000/(4*256*256))
#int_rtcc                                    // This function is called every time
void clock_isr() {                      // the RTCC (timer0) overflows (255->0).
                                              //For this program this is apx 76 times
    if(--int_count==0) {           // per second.
      ++seconds;
      int_count=INTS_PER_SECOND;
   set_timer0(0);
   setup_counters( RTCC_INTERNAL, RTCC_DIV_256 | RTCC_8_BIT);
   enable_interrupts(INT_RTCC);
   (while 1)
      if(seconds == 180)
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Mon Dec 03, 2007 6:28 am     Reply with quote
I think you should reset your second counter, like this:
if(seconds == 180)
      seconds = 0;
else the seconds keep increasing until it overflowes to 0. Depending on your declaration of seconds, this might take 75 seconds longer in case of a int8 declaration. But also much longer for int16 or int32 declaration.
I hope this helps
PostPosted: Mon Dec 03, 2007 8:10 am     Reply with quote
Also, from the CCS manual on Setup_counters():
This function is provided for compatibility with older versions. setup_timer_0 and
setup_WDT are the recommended replacements when possible.
SerialGmr8
PostPosted: Mon Dec 03, 2007 9:26 am     Reply with quote
mcuh thanks. I will give this a try and let you all know how it goes.
SerialGmr8
Much thanks.
PostPosted: Mon Dec 03, 2007 10:42 am     Reply with quote
Thanks to all for their most valued assistance.
The following code implements a 3 minute timer on timer0.
#if defined(__PCM__)
#include <16F877.h>
int8 ledstate;
int8 seconds;      // A running seconds counter
int8 int_count;    // Number of interrupts left before a second has elapsed
                                   // For this program this is apx 76 times
    if(--int_count==0)            // per second.
     ++seconds;
   set_timer0(0);
   output_low(pin_c7);
   seconds = 0;
       if(seconds == 180)
          if(ledstate==0)  //this routine will keep switching the value of your
            {                          // each time the routine gets entered.
             ledstate=1;
             output_high(PIN_C7);
             ledstate=0;
             output_low(PIN_C7);
         seconds = 0;
Foppie
PostPosted: Tue Dec 04, 2007 1:51 am     Reply with quote
one comment:
   ledstate=1;
   ledstate=0;
   output_low(PIN_C7);
could be replaced by just output_toggle(PIN_C7);
SerialGmr8
PostPosted: Tue Dec 04, 2007 6:21 am     Reply with quote
duely noted Foppie.
much thanks
