RCREG not empty
Shoebie
RCREG not empty
PostPosted: Wed Nov 28, 2007 3:38 pm     Reply with quote
I'm using a PIC16F876 with CCS ver 4.023. I am trying to capture a string from another source. I have found that the RCREG register is not empty. I try a read and still get a "Wrong" byte. Here is my code.
fputc('V',HW_RS232);
string_conversion();
char Hex_Dec(void)
   char chr;
   Rx_Tmr_On();
   chr = getg();
      if(chr <= (0x39) && chr >= (0x30))
         chr=(chr-(0x30));
         chr=(chr-(0x37));
      Rx_Tmr_Off();
      return chr;
void string_conversion(void)
   unsigned char ch;
   DUT_monitor = 0;
   Count = 0;
   Read_Rx();
        set_tris_c(0xff);
        if(Count<=6)
        ch = Hex_Dec();
        DUT_monitor = ch;
        DUT_monitor = (DUT_monitor << 4);
        if(Count<=6)
        ch = Hex_Dec();
        DUT_monitor = DUT_monitor + ch;
        if(Count<=6)
        ch = Hex_Dec();
        if(Count<=6)
        ch = Hex_Dec();
If I leave out the fputc function, the uart will rx the correct character. I have to send out this character to recieve data. I tried reading RCREG and RCSTA before the fputc and it didn't help. For this debugging, I used hyperterminal to send data.(hex numbers). Count is used in the interrupt routine, so I don't hang with lack of data. Is there another way I can insure the RX buffer is empty? Read_Rx is the routine I use to read RCREG.
PostPosted: Wed Nov 28, 2007 4:09 pm     Reply with quote
See the clear_usart_receiver() function in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=1571&start=3
See the reset_uart() function in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=6649&start=1
Shoebie
PostPosted: Wed Nov 28, 2007 4:24 pm     Reply with quote
Thank you for the very quick reply.
This is my clear function:
void Read_Rx(void)
   char u;
   u=RCREG;
   u=RCREG;
   u=RCREG;
Somehow, after a printf, a character sneeks into the RCREG. Not all the time. I have to send a character, then RX. I don't have time to run Read_Rx or I might miss a character. Is there a safer function that fputc that I should consider using ?
PostPosted: Thu Nov 29, 2007 3:33 am     Reply with quote
Seriously, have you tried putting a logic analyser/storage scope onto the serial receive line, and triggering it off the data being sent?. A character appearing in the receive buffer, really suggests that you may have some noise present on this line, that is just occasionally resulting in a 'low' being seen, and triggering a 'receive'. I really would suggest that you have a hardware issue, and that it should be rectified...
Eugeneo
PostPosted: Thu Nov 29, 2007 3:55 am     Reply with quote
I would suggest using an RDA interrupt. This code may be unreliable if you are not using the hardware uart since it doesn't look like you're polling it fast enough.
Shoebie
PostPosted: Thu Nov 29, 2007 9:08 am     Reply with quote
Thanks for the help. Using the RDA interrupt cured the problem. Now I fputc, then clear rcreg. The interrupt captures the characters I need.
