PIC18F4550 internal clock
biertafel
PostPosted: Wed Nov 28, 2007 9:37 am     Reply with quote
hello,
we want to program a PIC18F4550 and use the internal clock
We have found this code:
#include <p18f4550.h>
#include <delays.h>
#pragma config FOSC = HS
#pragma config PWRT = OFF
#pragma config BOR = OFF
#pragma config WDT = OFF
#pragma config CCP2MX = OFF
#pragma config LVP = OFF
   TRISA=0x00;
   ADCON1=0b00001111;
      PORTAbits.RA0 = 1;
      Delay10KTCYx(200);
      PORTAbits.RA0 = 0;
      Delay10KTCYx(200);
We use MPLab v7.6 with MMC18 compiler (student version).
We use MPLab ICD 2 to load the program in the pic.
We connect a LED and a resistor at RA0 and it seems that nothing is happening.
We think that the choice for the clock is wrong
we found on other sites that
has to be changed to
#pragma config FOSC = INTRC
but when building this we get an error
Make: The target "C:\Documents and Settings\Matthijs te Lintelo\Bureaublad\Biertafel programmeren\programma's\07-11-24_1\07-11-24_1\blinkled.o" is out of date.
Executing: "C:\MCC18\bin\mcc18.exe" -p=18F4550 "blinkled.c" -fo="blinkled.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
MPLAB C18 v3.14 (feature limited)
Copyright 1999-2005 Microchip Technology Inc.
This version of MPLAB C18 does not support the extended mode
and will not perform all optimizations. To purchase a full
copy of MPLAB C18, please contact your local distributor or
visit buy.microchip.com.
C:\Documents and Settings\Matthijs te Lintelo\Bureaublad\Biertafel programmeren\programma's\07-11-24_1\07-11-24_1\blinkled.c:5:Error [1225] configuration value 'INTRC' not recognized for configuration setting 'FOSC'
Halting build on first failure as requested.
BUILD FAILED: Wed Nov 28 16:20:06 2007
Here it looks like we have the wrong code or the compiler can't compile it (because of student version)
can anyone help us with this problem?
Matthijs & Wouter
amcfall
PostPosted: Wed Nov 28, 2007 9:46 am     Reply with quote
This forum is for the *CCS* compiler, not the Microchip C** series. Try the Microchip forums. The syntax is very different for pre processor directives.
Avery
biertafel
PostPosted: Wed Nov 28, 2007 9:49 am     Reply with quote
ow Embarassed
sorry Embarassed
