Hi all,
I am a newbie to CCS compiler. I am trying to setup the device header file to point to the specific address and it's not working for me. see example below
I don't want to use the setup_ccp1(CCP_PWM) function as it doesn't give me much info.
Mark
Posted: Mon Nov 26, 2007 5:52 am
Just use the #byte declaration:
#BYTE CCP1CON=0x0FBD
Your pointer declaraion, ought to be possible to make work, probably with:
#define CCP1CON (*(int8 *)(0x0FBD))
However the byte declaration is easier, especially since it also allows #bit declarations as well. It is the volatile keyword, that will prevent it working.
Ken Johnson
Joined: 23 Mar 2006 Posts: 197 Location: Lewisburg, WV
Posted: Mon Nov 26, 2007 8:28 am
I like these:
#pragma BYTE T0CON = getenv("SFR:T0CON")
#pragma BIT INT0IF = getenv("BIT:INT0IF")
