How do you use the switch statement
Allen
PostPosted: Fri Jan 02, 2009 4:16 pm     Reply with quote
I am using a 12F509 and want to switch between two led patterns using a push button to switch between each pattern. I have seen the code for the switch statement but do not know how to use it.
Could someone please help me.
Thank You
Allen
PostPosted: Fri Jan 02, 2009 4:31 pm     Reply with quote
Please don't do multiple posts on the same topic. Here is your previous
thread, which did get one answer. You should have added your new
question to that thread.
http://www.ccsinfo.com/forum/viewtopic.php?t=37215
But anyway, for links to pushbutton code see this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=36222
That link also shows how to use the switch-case statement.
Here is a tutorial on C, which explains the switch statement.
http://cslibrary.stanford.edu/101/EssentialC.pdf
