sin int 32 subtraction of minus sign data problem
w2drz
PostPosted: Sat Nov 24, 2007 1:05 pm     Reply with quote
using CCS 3.249 compler
18F4580 PICC
20 MHz
I can do a work around but it would not be nice!!
so and suggestions would be good
tom
problem found and it is not a compiler problem,
thanks to all
tom
PostPosted: Sat Nov 24, 2007 2:37 pm     Reply with quote
Look at your post before you submit it. You have little pieces of the
"code" block symbols before and after your code. Delete those.
Also, the first one must say "code". The last one (at the end) must
say "/code". Both must be inside brackets. Edit your post and fix
all those things.
PostPosted: Sat Nov 24, 2007 3:30 pm     Reply with quote
Also, post your declaration of SINT32. Since this is not a native type, you are presumably declaring it somewhere, and just occassionally, declarations like this, don't function quite as you expect.
SET
PostPosted: Sun Nov 25, 2007 1:44 pm     Reply with quote
void AdjustZIndexes (IndexData *pIdx, SINT32 diff)
   int   i;
   for (i=0; i < 16; ++i) {
      if (pIdx->IArray [i] == 0)
         break;            // no more
      pIdx->IArray [i] += diff;
Are you saying that the routine above always *added* 'diff' (even if it was negative)?
