g159 Guest
| MAX232's suitable for RS-232? |
Posted: Mon Oct 22, 2007 3:53 pm |
Hi guys,
I am trying to convert TTL signals from the PIC to RS-232 levels. I have a MAX232N chip from TI and the output is +-8.5V. I thought that RS-232 was supposed to be+-12 V, though. Or is this not the universal standard for everything? Can i still use the max232n for something like rs-232 communication with a PC?
Thanks a lot guys. |
g159 Guest
Posted: Mon Oct 22, 2007 5:32 pm |
Ok, thanks for the link to that site, I see that anything from 3-25 V can be used.
Say the PC i want to communicate with is outputting +-12 V signals. So even then, the fact that only +-8.5 V is coming out of the MAX232 will not "interfere" or "confuse" the PC then, since it expects 12V?
Thanks again- |
Posted: Mon Oct 22, 2007 5:50 pm |
The PC does not expect +/- 12v. Anything over +/- 3v will be
acceptable, according to the spec. To allow for voltage drop over
distance in the wires, and for a noise margin, the drivers put out a
higher voltage than the minimum requirement.
Use the MAX232N. Just plug it in, connect it up according to the
schematic, and go. |
BLL
Joined: 11 Nov 2006 Posts: 181 Location: Birmingham, UK
Posted: Tue Nov 20, 2007 8:33 am |
Why not use the MAX233 - no external capacitors needed so PCB space is saved? Samples available even!!
Brian |
SherpaDoug
Posted: Tue Nov 20, 2007 8:54 am |
| BLL wrote: | Why not use the MAX233 - no external capacitors needed so PCB space is saved? Samples available even!!
Brian |
For production the MAX233 is about double the cost of the MAX232 and has few second sources.
Sometimes the size of the product is determined by the size of the customers fingers. Smaller is not always better. _________________ The search for better is endless. Instead simply find very good and get the job done. |
dbotkin
Joined: 08 Sep 2003 Posts: 197 Location: Omaha NE USA
Posted: Thu Nov 22, 2007 11:41 pm |
The *spec* says +/- 3V or better. If you take a look at the actual requirements of every RS/EIA-232 line receiver since dinosaurs roamed the Earth and ICs had ceramic packages, I have yet to find any that actually *required* a negative voltage. Ever. In fact, the guts almost always have a clamp diode to whack any negative voltage.
Check http://www.botkin.org/dale/rs232_interface.htm (or the latest ARRL Handbook)if you want to see a dead simple, dirt cheap interface that has so far worked with anything I've connected it to. It's also worked with anything many hundreds of users have connected it to. It's what I have been using for a couple years now on my ID-O-Matic kit, and so far no one has yet come up with anything it won't talk to. In small lot quantities it will cost you less than $.20 and take up less board space than a MAX-2xxx device.
You're welcome.  |
