how to get 2 digits from float
PostPosted: Fri Nov 09, 2007 6:41 pm     Reply with quote
Hello, can any1 tell me please how to get 2 digits and one decimal digit from a float value?
Ex: float i=128.4;
I need to get 28.4
thank you all
PostPosted: Sat Nov 10, 2007 1:40 am     Reply with quote
Is the purpose to extract these digits so they can be displayed ?
You could use the sprintf() function. This will convert the floating point
value into an ASCII string and put it in a buffer. You can then scan the
buffer and find the location of the decimal point. Then you will know
where the other digits are located in the buffer, and you can display them.
PostPosted: Sat Nov 10, 2007 4:21 am     Reply with quote
Figures,
i need to show it on several 7 segments. Sprintf might help me.
thank you very much,
regards
PostPosted: Wed Nov 21, 2007 9:21 am     Reply with quote
http://www.edaboard.com/viewtopic.php?t=150005
http://www.coolcircuit.com/project/meter/index.html
Bye
