AnthonyF Guest
Interrupts changing variables as they are being used |
Posted: Sat Nov 10, 2007 6:42 pm |
I am doing a comparison using an if statement on a 32-bit variable. There is a hardware interrupt that will change this variable. Is it possible for the interrupt to happen in the middle of the comparison? Could this be a problem?
int32 counter = 0;
#int_ext
void ext_isr(){
counter++;
void main(){
while(TRUE){
if(counter > 50000)
run_task();
Thanks! |
SherpaDoug
Posted: Sat Nov 10, 2007 9:01 pm |
Yes, that is a common problem with multi-byte comparisons and interrupts. The solution is to disable relevant interrupts while the comparison is made. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Ken Johnson
Joined: 23 Mar 2006 Posts: 197 Location: Lewisburg, WV
Posted: Sun Nov 11, 2007 8:32 am |
Better yet, disable ints, copy the variable to a temp, enable ints, then do the compare (in the interest of keeping ints off as short a time as possible)
Ken |
