Mysterious #ROM
jt06
Mysterious #ROM
PostPosted: Tue Nov 06, 2007 2:34 pm     Reply with quote
I have to write some values in EEPROM of a 18F4620 at programming time.
I use the code below:
#rom int8 0xF00020={0x41,0x64,0x43,0x64,0x4B,0x54,0x52,0x20,0x35,0x37,0x32,0x35,0x49,0x6E,0x69,0x74}
My software does not work correctly, so I have controled the EEPROM content with WinPic800 and the result is:
I have only one byte over two in the EEPROM !!! Shocked
The same think with IC-Prog.
Does anyone have an idea?
Thank's in advance for your help.
PostPosted: Tue Nov 06, 2007 2:57 pm     Reply with quote
Compile a test program and look in the hex file.
Test program:
#include <18F4620.h>
#fuses XT,NOWDT,BROWNOUT,PUT,NOLVP
The eeprom data is in the Hex file:
:020000040000FA
:1000000002EF00F0F86AD09EEA6AE96AC150C00BBC
:0C0010000F09C16E070EB46EFFD703008D
:0200000400F00A
:10002000416443644B54522035373235496E69740C
:020000040030CA
:0E00000000011E1E008381000FC00FE00F40A4
:00000001FF
;PIC18F4620
You didn't post your compiler version. This program was compiled with
PCH vs. 4.059.
jt06
PostPosted: Tue Nov 06, 2007 3:20 pm     Reply with quote
I have compiled the test program and the result is the same:
:020000040000FA
:0200000400F00A
:020000040030CA
:00000001FF
;PIC18F4620
My compiler version is 4.049
Regards
PostPosted: Tue Nov 06, 2007 3:31 pm     Reply with quote
Try a different programmer software.
PostPosted: Tue Nov 06, 2007 3:37 pm     Reply with quote
It looks like your programmer is handling this wrong then.
If you look at the two lines:
:0200000400F00A
The first is an 'extended address'record, setting the offset to 0F000000, and the next loads 16 bytes, at 0020 from this point.
The compiler is generating the values correctly, but it looks as if your programmer is incorrectly handling this. I think it is getting confused by the fact that the EEPROM, like the main memory in the 18 series, is programmed in 16bit words, and is 'losing' the alternate bytes, and half the address offset.
You need to talk to the programmer manufacturers.
jt06
PostPosted: Wed Nov 07, 2007 11:55 am     Reply with quote
You're right.
It was a problem with the configuration of WinPic800.
It's necessary to uncheck :
File .HEX -> Data 18Fxxx Address * 2
in the Software Settings.
Thank's a lot for your helps.
Best regards
