Making two Function Work in main
PostPosted: Wed Nov 07, 2007 3:43 am     Reply with quote
Hi please help me i had two functions one for Time and second for Adc value
i can't make the two function work together
Here is my code :
#include<16f876a.h>
#use delay (clock=20000000)
#include "lcd.c"
#fuses HS,nowdt
int sek=0,min=0,hour=12,i;
#define  HourB PIN_A3
#define  MinB  PIN_A1
#define  SetB  PIN_A2
   int1 AmPm;
void clock()
   while(true)
      delay_ms(1000); // Time
      printf(lcd_putc,("\f"));
      printf(lcd_putc, " %2u",hour);
      printf(lcd_putc,(":"));
      printf(lcd_putc, "%02u",min);
      printf(lcd_putc, "%02u",sek);
      sek++;
      If(sek>59)
         sek=0;
         ++min;
      if(min>59)
         min=0;
         ++hour;
      if(hour>12)
         hour = 1;
         AmPm = !AmPm ;
      If(!AmPm)
         printf(lcd_putc, " AM");
         printf(lcd_putc, " PM");
      if( !input(HourB) ){
hour++;
delay_ms(50); //debounce
            if( !input(MinB) ){
               min++;
                    if( !input(SetB) ){
                    AmPm = !AmPm;
void adcvalue()
   // Setup A/D
   setup_adc_ports(RA0_ANALOG);
   setup_adc(ADC_CLOCK_DIV_32);
   set_adc_channel(0);
   delay_us(100);
   while(true)
      i = read_adc();
      printf(lcd_putc, "\n temp %lu ",(i*5/1023)- 5);
 lcd_init();
 while(true)
  clock();
   adcvalue();
PostPosted: Wed Nov 07, 2007 4:04 am     Reply with quote
Think about what your functions are doing.
Will either ever _exit_?.
How can the second one be called in this case?.
Your loop in the 'main' is the only permanent loop that should exist. Each function must do it's task, either once, or a number of times if required, and then exit, to allow the other to execute.
PostPosted: Wed Nov 07, 2007 4:12 am     Reply with quote
thanks a bunch
i removed the while loop from two functions and keep the one in main
Thanks again Very Happy
PostPosted: Wed Nov 07, 2007 4:18 am     Reply with quote
i had little issue with Am/Pm thing
 if(hour>12)
         hour = 1;
         AmPm = !AmPm ;
i want it every 12 hours to toggle but it toggles after 12:59:59 AM
-> 1:00:00 PM
PostPosted: Wed Nov 07, 2007 5:20 am     Reply with quote
if (hour>12 && min==0 && sec==0)
PostPosted: Wed Nov 07, 2007 5:36 am     Reply with quote
doesn't work
the hours start counting 13 14 15
when i set hours
Wayne_
PostPosted: Wed Nov 07, 2007 6:32 am     Reply with quote
if (hour > 11)
AmPm != AmPm;
if (hour > 12)
hour = 1;
PostPosted: Wed Nov 07, 2007 6:56 am     Reply with quote
f (hour > 11)
AmPm != AmPm;
if (hour > 12)
hour = 1;
This will toggle the AM/PM variable at every pass in the loop when the hour == 12.
There are several ways to display times. Can you elaborate a bit more on how you want the time to be shown?
For example I'm used to see the time on my watch as:
0:00:00 to 11:59:59, at the overflow of 11:59:59 the AM/PM sign toggles.
From your code it looks like you want the time to be shown as:
1:00:00 to 12:59:59
But at what which time do you want to toggle the AM/PM change ???
PostPosted: Wed Nov 07, 2007 7:02 am     Reply with quote
sorry doesn't work
if (hour > 11)
note that clock will return after 12 to 1
this code make the am/pm toggling (12:00 to 12:59)
PostPosted: Wed Nov 07, 2007 7:09 am     Reply with quote
i want it to toggle every 12 hours
when it's 12:00:00
PostPosted: Wed Nov 07, 2007 7:39 am     Reply with quote
The best way is to put the hour test _inside_ the minute test. So:
      if(min>59)
         min=0;
         ++hour;
         if (hour>12) {
            hour=1;
            AmPm^=1;
PostPosted: Wed Nov 07, 2007 8:02 am     Reply with quote
This still toggles am/pm at the overflow of 12:59:59 to 01:00:00.
If you want AM/PM to toggle at the change from 11:59:59 to 12:00:00 change the code to:
if (sek>59)
   sek=0;
   ++min;
   if(min>59)
      min=0;
      ++hour;
      if (hour==12)
         AmPm = !AmPm;
      if (hour>12)
         hour=1;
PostPosted: Wed Nov 07, 2007 9:06 am     Reply with quote
it keep goes 12 13 14 15
doesn't work
